Question about E-Machines eMachines Desktop PC
After using restore CDs to restore my E-Machine desktop T2542 because of a virus problem, I have no sound. I am running Windows XP. I identified that my audio device on high output buss required a Realtec 97 driver. While this driver is supposed to be on Restore CD#2 it does not appear to be there or does not appear to download. I went to the Realtec Website and downloaded the indicated driver. I still have no sound. What more/else do I need to do. Yes, speakers appear to be properly plugged in and turned on as the indicator lights are on and volume control on speakers is at maximum. Any thoughts would be appreciated. Thanks, Larry
  • 977 Answers
Hi Larry!
First, have a look at the Device Manager.
Do you see any red Xs, yellow question marks or exclamation marks?
Look under Sound, video and game controllers... Is Realtek AC'97 listed? What other devices are listed?
Second, enter the BIOS (usually done by pressing DEL or F2 while computer starts booting up).
I'm not sure how your exact BIOS look like, but look for Integrated Audio, or something like this (search for the word Sound or Audio), and make sure it's not Disabled.
Third, try connecting the speakers (given that they are NOT powered by USB) to any other music/sound source (MP3 player, etc.) and see if they work properly.
Waiting to hear from you,
Pelu.
PS: If none of the above worked for you, please don't automatically reject my solution... I have others for you, but first I need you to try the ones above!
Posted on Jul 06, 2010
  • 10 more comments
  • the_nuts Jul 07, 2010
    Keynan:
    Thanks for your quick reply. Had to get some sleep so am only able to respond now.
    1. Concerning "Device Manager": No red X's; 3 Yellow ?s - "Other Devices" with subheadings "Audio Device on High , Definition Buss" and "Video Controller (VGA Compatible)". No exclamation marks. 1.a Under Sound. Video and Game Controllers, Realtec 97 is NOT listed. The listed items (6) include Audio Codecs, Legacy Audio Drivers, Unimodem Half-Duplex Audio Device, Media Control Devices, Video Codecs, and Legacy Video Capture Devices.
    2. When I press "DEL" during boot-up, I get a screen headed "Phoenix - Award Bios CMOS Setting Utility. However I can find nothing on this page or the available links which are titled "Sound" or "Audio" or which have anything to do with these functions. I do get a "WARNING" message in the middle of the Bios page which says "Refresh Rate Exceeds Valid Range - please reset to 60 Hz, otherwise display is erratic."
    2.a. Ignoring the Warning and completing the boot up, I frequently get a "Newly Found Hardware" screen for "Audio Device on High Definition Audio Buss" Following procedures for the new hardware installation , I get an Install Wizard which directs me to insert Restore CD which I do, but after a long search it says it still can not find appropriate driver. It also suggests it can look for driver on line but I can not get it to do so. If I go to my list of temporary "Downloaded files", I can find "RealTec 97". Double clicking on this starts the install process for Realtec but 1/2 way through I get an error message which says "Sorry, error encountered and computer must close" However if I check OK at this point, the computer does not close but appears to complete the download. Later however I still can not find Realtec 97 on Device Manager.
    3. Speakers do work when plugged in to other audio sources.
    Still at Square 1, where do we go from here?
    Larry
  • Ran Kedar
    Ran Kedar Jul 07, 2010
    Hi again!
    It seems like FEW things are missing and needed to be installed.
    • First, make sure you have the latest Service Pack for Windows (which is Service Pack 3 or SP3). To do so, right click on My Computer and select Properties. You'll see there which service pack you have. If update is needed, go to Windows Update and go through the update process.
    • At last, download the audio driver from here and install it.
    Good luck,
    Pelu.
    PS: I couldn't figure out from your answer which was the 3rd question mark device, but I think the drivers I've provided will cover it as well...
  • Ran Kedar
    I would also recommend you to go into the BIOS again and select "Reset to Factory Settings"or "Load Defaults" (or something like it...), so you'd get rid of that error message you get!
    You might need to reset the time and date in the BIOS after doing so.
    Pelu:
    Thanks for your help but I do not seem to be having much luck.
    Then attempting the first download from the Intel Download page, I got message
    " The Intel Chipset Software Installation Utility requires a supported chipset platform running on a supported operating system. Check the System Requirements section of the README.TXT file for more information". It then returns to the Downloads page.
    When attempting your second recommended download from the Intel Downloads Web page, I get the message " This system does not meet the minimum requirements for installing the software. Setup will now exit".
    When trying to download the driver I get the message. "Not Found. The requested UFL.xxxxxxxxx, was not found on server"
    One last note I do find two Realtec programs on "Add or Remove Programs" list under "Control Panel" One is realtec 97 Audio and the other os RTL8139 Fast Ethernet.
    Any more thoughts? Larry
    Pelu:
    I forgot to mention... I am running Service Pack 3 on my XP Home Edition
  • Ran Kedar
    Ran Kedar Jul 10, 2010
    Larry,
    The downloads from Intel were according to your system configurations, as I found on eMachines' site. Apparently your system configurations is different...
    Run this and see if you can tell me your motherboard's model and manufacturer (look at Mainboard tab).
    Try installing the CHIPSET and VIDEO/GRAPHICS drivers from the CD you have, or use above tool to write me which chipset you have on your motherboard (Mainboard tab again)!
    Please UNINSTALL Realtek AC'97 Audio Driver through Add/Remove Programs, restart and install the latest version.
    Note: It might still fail to work as long as the chipset drivers are not installed! Plus, it might be other driver than Realtek AC'97...
    Regards,
    Pelu.
  • the_nuts Jul 10, 2010
    Pelu:
    You must think I am a real computer dunce but when I checked on the link you sent me to identify my motherboard, I got "The page cannot be found" HTTP Error 404.
    When I attempted to use the Remove files under the Control Panel for my currently installed Realtec 97, I run into a "Error Extracting Support Files" "Catastrophic failure" Checking OK which then returns me to the "Add/Remove files" site.
    The downloads you wanted me to run including the ones for an update of the Realtec 97 driver all lead to sites which scan my system drivers and then want payment to fix same. After paying money to access FixYa am I still supposed to pay for other site assistance? I did go to one of these Sites (Driver Doctor) got the scan and paid for support - which still did not manage to solve my sound problem.
    By the way during one of the scans the diagnosis program identified my computer as a "BioStar Intel Socket 478". Does this help you with my problem? Thanks, Larry
  • Ran Kedar
    You're right, it seems like FixYa messed-up the link...
    Copy and paste this in the address bar of your browser:
    ftp://ftp.cpuid.com/cpu-z/cpu-z_1.55-32bits-en.zip
    BIOStar Intel 478 is just not enough info...
    Go into this site again... To download the driver for FREE, all you need to do is clicking on "Download@MajorGeeks" (one of the 2 links in the middle). If it doesn't popup the download window, click on "CLICK HERE IF IT DOES NOT" (at the top).
    Ignore the uninstallation problems for the moment...
    Good luck,
    Pelu.
    PS: FYI, most of the payed "services" and "tools" online are completely SCAMS! Don't be easily tempted to pay - only if you have a basis of trust in the site (such as FixYa :)
  • Ran Kedar
  • Ran Kedar
    OK, so FixYa just can't handle FTP links! That's too bad....
    Please use this link instead!
  • the_nuts Jul 11, 2010
    Pelu:
    I was finally able to follow your final link and was able to unzip the downloaded file.
    The CPUID reader told me that I am running an Intel Celeron processor, CPU 2.50v
    The mainboard is listed as a Biostar Group model P4M90-M4 . Does this provide the data you have requested?
    Larry
  • Ran Kedar
    Ran Kedar Jul 11, 2010
    Well, that explains a lot... It has different Audio device than Realtek AC'97!
    Though, there are 2 options (as there are 2 versions for this models):
    1) Ver. 6.0/6.1
    2) Ver 6.2
    Download and install in this order: Chipset, RESTART, On-borad VGA, On-borad Audio, RESTART.
    Unistall the inappropriate drivers if they get installed.
    Good luck again,
    Pelu.
How do i restore the emachine
Remove any DVDs or CDs from the optical drives and then unplug all peripheral devices except for the keyboard and mouse.
Click the "Windows" button and then type "eMachines recovery management" into the search box. Click on "eMachines recovery management" in the results list and then click the "Restore" tab.
Click "Password Settings" and then type a new password into the text box.
Click "OK" and then click "Restore System to Factory Default".
Type the recovery password into the "Password" text box and then click "OK". Click "Next" To start the recovery process.
Click "Finish" and then wait for your computer to restart.
This procedure could take several minutes. Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings.
or if you are running XP
If you set your machine back to eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order.
You should get rid of this virus with an effective virus remover.
You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html
If you know when you got the virus, you can do a system restore to a time before the virus was on your system. This article tells you how to run it from safe mode http://bertk.mvps.org/html/safemode.html
Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009.
More information here http://www.ask-the-computer-doc.com/comp...
If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one.
You might also try a Windows repair install if you have the operating system disk. Follow the directions here for XP http://www.michaelstevenstech.com/XPrepa...
Source(s):
hope this helps
Sep 16, 2012 | E-Machines eMachines Desktop PC
My friends computer has a virus. She uses Avast Antivirus which I've always had good luck with. Her computer is an Emachine with windows XP operating system. Avast found a virus after running a thorough...
It may not be a virus. It sounds more like a bad case of spyware. You may want to download, install, update, and run something like Malwarebytes AntiMalware. It sounds pretty serious, so it may need the attention of a PC technician to fully remove the infection.
Hope this helps!
Matt B.
Feb 02, 2010 | E-Machines eMachines Desktop PC
My eMachines T3882 with Windows XP just reboots over and over
Sounds like a sick hard drive. When it starts to reboot, press F8 and choose Windows Diagnostic Test. It will show a hard drive failure if one exists. If it finds a hard drive error, the hard drive is junk and needs replacing. Once replaced, you can run your restore/recovery disk to install Windows back to the condition it was in when you bought it.
Dec 16, 2009 | E-Machines eMachines Desktop PC
Recently re-installed windows xp on my e-machines T2542 and now my speakers (Diamond Audio Techonology Model EMC2.0-USB) do not work. I downloaded RealTek AC '97 Audio, but it does not show up in my Device...
Good day sir, hi, the realtek you downloaded maybe is not the correct driver, the driver is the ALC202 from this website: http://mxdtr.com/index.php/category/emachines-trigem-imperial-g-motherboard-driver-drivers-download/
You can visit this site for the driver:
http://www.lostmydrivers.com/soundcard-drivers/realtek/page_3.html
Run the driver once again, when windows detect the device, dont reply, just let the driver finish the installation. then restart the pc. thats it. thanks
Nov 04, 2009 | E-Machines T2542 PC Desktop
I just lost all my cd 's with my emachine t2542,i re install new W XP OS because my hard disk was damaged and replace new one,the problem is,it's usb ports doesn't work,help me pls.tnx
In order for us to assess possible drivers that are available for the eMachines T-Series T2542, please download the trial of Driver Detective and run it to ensure a more accurate list of drivers for your computer with less chance of error.
http://www.drivershq.com/Drivers/eMachines/T-Series/T2542/22605/22647/22688/Drivers.aspx
Oct 05, 2009 | E-Machines T2542 PC Desktop
Emachine EL 1200 06w Restore ???
tjbrown527 --
I have no idea about the difference between XP Home and "Nettops", lol! But, I can help you restore :)
Reboot your PC, when the very first screen comes up (the manufacturer's screen, the one before the Windows splash) press and hold F8 (or tap repeatedly). This will take you to a boot-options menu. Choose "Boot in Safe Mode", allow windows to load.
When it is finished loading, you may be given an automatic choice of either running System Restore, or finish loading in Safe Mode. Choose System Restore, and restore to a date (on the little calander) sometime before your issues came up.
If you are not prompted automatically, and instead it loads to the desktop, go to Start Button ---> Help and Support ---> and under "Pick a Task" choose "Undo changes to your computer with System Restore". Again, pick a date and let 'er rip!
(you can also find it in Start Button ---> Programs ---> Accessories ---> System Tools ---> System Restore)
*****If you are not having problems with your boot, and simply want to restore, you can skip the F8 way and just go straight to restore from your normal desktop!
Whew! Hope some of this helps!
If you need any further assistance, please feel free to post a comment to this post and I will be glad to help!
-- RT
PS - If useful, don't forget to vote!
Sep 09, 2009 | E-Machines eMachines Desktop PC
Restoring pc
just give it a name like "rick computer" or "my pc" it is for identifying ur pc on the network, nothing special needed and it does not have to be the same as the old one makes no difference. Something has to be there though.
Joe
May 26, 2009 | E-Machines T2542 PC Desktop
An unknown error tell me pzzzzzzz
Apparently your XP is missing some needed component to complete the task you are trying to perform. When and in what context does this message appear, as that will give a clue as to the missing component(s).
I notice that you do not have the Windows XP style selected as your taskbar is grey, not blue. Was it always this way or did it change by itself. If it just changed one day, it could be a sign of hard drive corruption (where it cannot access the XP theme) or virus infection (where a virus deliberately disables various system functions to prevent you from using the machine).
Did you have a recent virus infection that was cleaned up? The anti-virus program may have removed some Windows files where the virus(es) attached themselves.
Start with the simple. Go to My Computer, right click on your hard drive, select Properties at the bottom, go to the second tab Tools and run a disk error check. Check the boxes for Automatically fix system error and Scan for bad blocks. You will have to reboot and be patient as this can take a while depending on the size of the drive. The computer will continue to the desktop when the disk check is complete. Listen for and ticking, knocking or attempts to keep reading disk sectors as this may be a sign of a failing drive.
After, download and run at least one antivirus scan. I can see you have CCleaner and uTorrent but I do not see any antivirus. If you have SP2 or SP3, install Windows Defender from Microsoft first. It is self explanatory, free and available here:)
http://www.microsoft.com/downloads/details.aspx?familyid=435bfce7-da2b-4a6a-afa4-f7f14e605a0d&displaylang=en
Note you must be running a legal copy of Windows XP for this to install.
The other antivirus I would suggest is AVG Free Edition, which is available from here:)
http://www.avg.com/filedir/inst/avg_free_stf_en_8_176a1400.exe
My final suggestion is to run a System File Check, but you need a Windows XP installation disk for that. The Compaq Restore CDs will not suffice as they are generally compressed and encoded.
Please post comments on your progress and results.
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
System recovery cds
I think the peoblem is that you need to set the cdrom as first boot device, go into bios (F2 or Del on boot up) and enter advanced cmos settings and you will find that the HDD (Hard disk) is set as first boot device, change this with up/down keys or + - keys to cdrom as first boot device. save settings and exit for a restart with cd in drive.
Aug 29, 2007 | Toshiba Satellite 2415-S205 Notebook
The quick restore dosen`t work
What operating system you are using before installing windows xp. If it is windows 98, Your restore cd will restore windows 98. if you want to restore to factory settings pls boot from the restore cd and format the harddisk. Becareful, this will erase your entire data on the harddisk which cannot be recover. If you are using licenced (not pirated) windows xp boot from it and reinstall windows xp so that you can run the os smoothly. But in either case becarefull when you are formating, it will destroy entire data and you may endup in soup. feel free to revert back for further quiries
Sep 29, 2006 | Compaq Presario 5000 PC Desktop
E-Machines eMachines Desktop PC Logo
181 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
