Question about Check Point Network Adapter
SAFE WILL NOT OPEN WITH COMB 159A - Check Point Network Adapter
    Scholar:
  • 170 Answers
Open with the overide key. replace the batteries. reprogram the code by pressing the red button on the back door . then enter 159B. then try to open with the code 159A
Posted on Aug 02, 2010
Have old 50 yrs weilink safe have comb. not opening
You could have the correct combo... but not be using the correct pattern. Here it is.
Turn dial several times to the right to clear it...stop on 0
Turn dial to left (ccw) 3 times past the first number and then stiop on that number the 4th time around.
Turn dial to right 2 times past the second number stop on that number the 5rd time around
Turn dial to left 1 time past the 3rd number and stop on the 2nd time around.
Turn dial to the right until it latches (could be the last number or the drifted number) until it stops
Twist handle and open door.
NOTE:If this fails to open it then its possible (after years of use and w/o service) that the numbers 'drift' from there original spot. You can try to find this out by applying pressure to the handle (which engages the 'fence' inside and rubs it against the wheel pack). While applying light pressure rotate the combo dial and where it locks up should be one of the numbers... check this against your 'correct combo' and see how they match. If it's off then all of them are off. You'll need to determine the 'new' combo by drawing the dial with the numbers use the fence located number (usually the first or last) and then reverse engineer the combination. You may also want to grab a book on safes/ safe-cracking to understand the mechanics if this doesn't make sense. Good luck!
Jun 03, 2014 | Safe International Digital Electronic Safe...
I can't find a telephone number for micromark to order a replacement safe key. Anyone have a valid phone number for them?
If the battery power has fallen too low the safe will revert to it's factory setting 159A or 159B if you have enough power to make the unit work one of these will open it.
The only way to get a replacement key is to call a locksmith out and have a key made.
Apr 17, 2011 | Locks & Locksmithing
Batteries ran out so i need to reset the code but i dont know how to its a micromark electronic safe
if it's in a cold room use a portable room heater for a few hours to raise the battery tempreture a few degrees this may give them a boost, then try the factory preset code 159A or 159B
Nov 13, 2009 | Safe International Digital Electronic Safe...
Micromark safe lost my keys. can i get a replacement key?
Oct 27, 2009 | Safe International Digital Electronic Safe...
I want to reset the entry combination
Try and use default code 159a then try and reset if not go to harborfreight.com put in safe it has instructions on how to change all these are the same even if name is different
Oct 02, 2009 | Safe International Digital Electronic Safe...
ACCIDENTLY LOST COMBINATION FOR DIGITAL SAFE , HAVE TO USE KEY
Take off front plate key will open, reset with default 159a should help
Sep 28, 2009 | Safe International Digital Electronic Safe...
Changing the code on standleford es20 safe
If the problem is that the safe is not accepting your pin code, try first code 159A, or 159B that are default codes to open the safe.
If you have the sentry key, open with key, and there is a red button inside the door to reset the code.
If you have no key and default code does not work, call sandleford number at 03 97750699 they will guide in opening the safe.
Nov 07, 2008 | O2 Xda Atom Exec Smartphone
Check Point Network Adapter Logo
143 people viewed this question
Top Check Point Computers & Internet Experts
steve morris
steve morris
ray gallant
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
