Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Turned t.v. on and worked then went down. unplugged waited for 20 minutes and turned back on. red blinking light on under word lamp and a tweeter noise
  • Panasonic Master
  • 11,800 Answers
The blinking LED under the word LAMP is there to notify you that the bulb that is providing the light on your tv has died and must be replaced.
 You can get one from here
http://www.amazon.com/Panasonic-PT-52LCX15-Lamp-MPN-TY-LA1000/dp/B0009TA728
The sound is generated by the power source, it's in protected mode - it has almost shutdown itself to protect itself against the overstress caused by the failed bulb.
Posted on Jul 06, 2010
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
Tv turned itself off and started blinking red light. i unplugged tv and waited and then plugged back in and waited for the blinking green light to go off. turned tv back on and it worked all day. today...
Try removing the projection lamp and reinstalling it. After you reinstall the lamp look for a small reset button near the projection lamp compartment. Could be on the right or left side.
Apr 12, 2014 | Mitsubishi WD65737 65" DLP TV
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. ...
Samsung HLN507W turns on for about one minute then shuts off, three blinking lights stay on in front. It is not the lamp, nor the blue lamp cover switch for sure. I unplug it and immediately turn it on. It always does the same thing: comes on for 1 minute, then powers down - there is no wait time in between unplugging and powering on. All fans seem to work and I cleaned the dust out of it. Help.
Nov 04, 2010 | Samsung HLN507 50" Rear Projection...
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
TV shuts down and blinks red 6 times
Lamp or Fan is going bad.Take lamp out see if it looks good if so listen/watch to see if Fan keeps runningwhen turned on if Fan stops running ,Lamp and power will not come on.!
Nov 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Apr 21, 2008 | Toshiba 43H70 43" Rear Projection...
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
