Question about LG WM2688H Front Load Washer
Code error te
After doing a load of towels an "error" mrsage came up stating to see owners manual. Also says te, if that means anything.
    Problem Solver:
  • 15 Answers
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Posted on Jul 21, 2010
How can I fix this?
Hello. There is an LE error that means "fill error". There is also a "tE" error that means "sump thermistor failure". You are probably getting the tE error--the thermistor is located at the bottom front of the washer tub in the center. If water is leaking from the bellow(the rubber part that seals tightly against the door), it might be spilling down onto the thermistor wires, shorting it out. With any leak, this will be an INVOLVED repair. My suggestion is to call for service--to reach anything in the front of the washer internally, the front panel must be removed--this is complex, and must be done carefully, especially if the bellow is leaking and needs to be replaced. I hope I helped you!
Aug 21, 2015 | Maytag MAH2400A Front Load Washer
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
I have a LG2487hm washing machine, the geek squad are a bunch of idiots. I have the TE code it only trips off line when the load is heavier than 3 or 4 towels. I looks like it is weight related. right...
TE is a Therrmistor error, The thermistor senses the water temp. As with any error code it could be the part, Wiring Harness or Computer which is causing the issue. If you try cold temp wash the cycles may work. Geeks should OHM out the part to see if that is at fault. LG has 2 different Thermistors. 1. Thermistor is part of the heat element.
2. Thermister is separate. LG part# 6322FR2046C.
Quick easy fix.
Hope this helps.
Mike
Oct 31, 2017 | LG WM2688H Front Load Washer
I have a TE 2000 casio till, it is printing Error 180 on the receipt roll & on the display it will state the relevant header ie reg, x, y, calc but will have flashing dotted lines under the heading....
This is an RS-232 error. It means the machine is trying to communicate with another device. If you have a PC or other device connected to the port, make sure you do not power it up with the cash register turned on or you will often receive this error. If the error just happens during normal use with nothing plugged into the port, then it has a fault. Some models were affected by this. It will often lock the register up until turned off and left to cool. A dealer can repair this problem. ------------------------------------------------------
If anyone needs more information, the Casio TE-2000 manuals are here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Aug 25, 2011 | Casio Parts Cash Register PC Desktop
My washer has a te error code, lost the owners manual, what does the te code mean and how do we fix it?
It means the THERMISTOR is faulty and most likely needs to be replaced. It's about a 7-10 dollar part, plus shipping. The problem is, you'll need to take the machine apart to replace. The best thing to do, is contact a professional for repairs.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
What doea the tE error message mean?
In the manual it does not have a cause... just shut off the power and call for service...
Feb 12, 2010 | LG WM-2277HW Front Load Washer
CD disk error
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
May 26, 2009 | 2007 Toyota Camry
Wm2032hw
tE error code means the thermistor has failed.  That part is located in the front of the drum next to the heater element.
Aug 08, 2007 | LG WM-2032H Front Load Washer
LG WM2688H Front Load Washer Logo
516 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
