Question about GE Zoneline AZ55H07D Air Conditioner
I have a ge ac model aew10ajs1. When you turn it on the temp just shows dashes and beeps and turns off. I dont have a manual just seeing if there is anything i can do?
5 Suggested Answers
mastatech
  • 478 Answers
SOURCE: air conditioner model AEW10AJS1 wiring problem.
That is the temp prob it belongs in the air flow, its only connected on one end
Posted on Mar 29, 2009
SOURCE: I bought a GE Air
Does the high pitched sounded continue or does it just occur when you turn the compressor on. Does it go off? If so, how long does it take? Please email me at whd2@columbia.edu Thanks very much. Bill Depperman
Posted on Apr 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: My GE AC starts to beep when I only turn it on for a while
Probably a bad sensor. Remove the sensor and clean it good or replace it. Todays newer stuff relies on a sensor to tell the beard what the conditins are in the house. The board sends a small dc voltage through the sensor and measures the sensor. Changes in temperature cause the voltage to fluctuate and this tells the brain when to shut down the machine. Long story short the sensor thinks the house is cool enough. Less than 5 bucks a sensor is easy to change out. It has a quick connect, check it for corrosion, with any luck all you need to do is clean it up.
Posted on Jul 17, 2009
  • 3 Answers
SOURCE: EP Message - no cool air on a GE Air Conditioner
I just posted this on another one, but try unplugging it and pushing the reset buttons on the side of the plug. It worked to fix mine so far...
Posted on Oct 19, 2009
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
AEW10AJS1 ac digital panel keeps climbing to its max of 86 degrees. i cannot operate any of the buttons except the temp down. i have to hold it down because the unit keeps climbing back up to 86. its a...
Greetings!
I have the same model. Symptoms: Unit works great, Expect..when operating the menu buttons, they do don work properly. Example, pressing the up temp works great, but when pressing the lower temp button, the temp will go to 86 degrees F.
The problem is the control board. I took it out, clean it well with soapy water, rinsed with clean water, blew dry, took a tooth brush with alcohol and rebrushed again, rinsed with water, blew dry with compressed air.
Upon close inspection with a magnifying class, you can see the top of the board connections, did not solder well when manufactured. This is a hint... My problem was with R32 a 0804 resistor not being soldered properly during manufacture.
I replaced the resistor an all is well.
All the buttons have ground at the bottom of the switches, while the top is 5v volts dc with a standard meter, but I do believe all the keys are multiplexed, as seen when pressing one of the buttons, the display may show a different function changing.
Thus the most likely problem, will be with one of the 10K ohm resistors associated with one or more of the buttons. The resister is black in color with 103 written on the top, and is a 0804 size.
Hope this helps.
PS I have found no replacement of the control board, so I just fixed mine. If you have electronics friend, he/she might like the challenge.
Jul 15, 2011 | GE AJCQ08ACB Air Conditioner
2003 malibu, replace fuel pump with a bosch lifetime warranty , intake head gasket, and battery now after five days my fuel gauge dont work, the temp gauge dont work, and the bright light turn on the high...
Sounds like the body control module for the light issues,the fuel gauge works off of the fuel pump , sound like maby the wire come loose at the pump . temp gauge make shure after you replaced the intake gasket that you didnt get a wire to the temp sensor pinched or next to something that could have melted the wire,If the wire gets hot and melts it will go to ground and cause alot of the probs your having in the dash, cause the wire will ground out and send signal to the body control module which in return cause all kinds of beeps and lights to malfunction.If there is no short it is the body control mdule has gone bad and if replaced should fix your problem.
Oct 07, 2010 | 2003 Chevrolet Malibu
Jul 27, 2009 | GE Heating & Cooling
Jul 17, 2009 | GE Heating & Cooling
AEW10AJS1 a\c digital panel keeps climbing to its
I have the same problem, 4 little kids in the house trying to keep them cool. Did you find out how to fix this?
thanks
Ian
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
Power will not turn on
If you know the outlet is good then you need to unplug the AC slide it out of the cabinet and see if the on off switch is working or if there is a loose or burned connection in the wiring circuit. check all wiring going and coming to capacitors and check to see if the continuity between the post on the control switch. There are many different models and each one has different features. So each one may be wired a little different. While you are inside the cabinet mart the wires going to compressor and where they connect. Let me know when you get to that point and I will lead you through the way to test the compressor. I don't think the compressor is the problem, I just want you check all connections for burns or bad connections, Thanks, Sea Breeze
May 20, 2009 | GE AJCQ08ACB Air Conditioner
Air conditioner model AEW10AJS1 wiring problem.
Mar 29, 2009 | GE AJCQ08ACB Air Conditioner
GE Zoneline AZ55H07D Air Conditioner Logo
101 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
