VOCOPRO KARAOKE PLAYER NOT READING - Audio Players & Recorders
  • jerryrice81 Apr 18, 2008
    CAN I MAKE THE ADJUSTMENTS?
    thank you. so, I can open the top and apply alcohol to the lasar lens? It started to go bad little by little. It would work some, then not at all, until finally, it did not read at all. I would put in a cdg and the first thing it would say is "reading" then after a moment it says "no disc" and I have tried alot of different discs. even one that was almost brand new.
  • 4,234 Answers
You should be able to get at the lens by opening up the top. Try cleaning this lens using a cotton swab and alcohol. There are electrical adjustments that can be made for tracking and balance that would effect its ability to read the discs as well. Let us know if cleaning works.
Dan
Posted on Apr 18, 2008
  • ABRsvcs Apr 18, 2008
    Unfortunately without some test equipment, the adjustments can not be made. Hwever, if these adjustments are required, the optics are starting to fail anyway and I'm not sure it would be worth the investment. Changing the optics should be around $30 or so for the part. These use common Sony optics assemblies (at least the ones Ihave seen do.)
    Dan
Can i replace the dvd player in my karaoke machine myself?
perhaps you could if you knew the make and model of the player and where to buy just that .. a phone call to a computer repair shop might answer what you wish to know
Dec 15, 2015 | KARAOKE Vocopro Champion-RV Player Machine...
Vocopro 8900 noise but no music
No power to voco pro 8900 cd player
Aug 09, 2012 | Music
I picked up a vocopro karaoke machine at a yard sale and the echo makes a loud hum also i need a owners manual and remote where can i get help with this. model#890G thank you
Hello. For the manual and remote your best option is to search online. As far as the echo goes, this is just a cheap microphone with a cheap system. It will not go away unless you turn the volume down on the system. If you want to put good money down on a nice SHURE brand microphone it will definitly help with the echo, however it will not make the system any better.
Apr 17, 2011 | Vocopro DVD-Duet Multi-Format Karaoke...
My cd player frequently ails to read the cd and recently the audio goes in and out.Its a Fleco.
Try CAREFULLY cleaning the CD reading lens with a Q Tip moistend with 91% isoprophyl alcohol... DO NOT use rubbing alcohol.
Check if your CD's have fingerprints or other contamination. Clean those with windex and a soft cloth rubbing ONLY outward from the center, NOT circular.
Dec 27, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
I trying to hook up an old record player to my Vocopro karaoke machine & I can't get any sound. What cables & where do I hook them
the record player should have a 2 sets of wires (one for power) and the other for left/right sound........you may need an adapter for this if there is no RCA plug in (if there is plug in AUX)
Aug 08, 2010 | Audio Players & Recorders
I need a channel slider for a vocopro mixer KJ7000
various types are avail at mouser and digi-key .com. google them -check their catalogue and search under potentiometer.verify value,physical dimension and shaft length.
Mar 03, 2010 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
I need a schematic for the vocopro entertaner model no HKH000011
You might try emailing the service centers listed here and see if you can get lucky:http://www.vocopro.com/servicecenter.php
Jan 23, 2010 | Vocopro DVD-Duet Multi-Format Karaoke...
My receiver is reading NO DISC it is a vocopro karaoke player/receiver model # DKP-10G
First, the player does not support DVDs or MP3 discs.
Try two things:
#1:
Unplug from outlet and Turn ON player (while unplugged).
Plug back in and try to use the CD.
#2:
Obtain a CD laser lens cleaner from Radio Shack ($13). It is an audio CD with a row of brushes and does not use chemicals
Oct 16, 2009 | Vocopro DKP-10G
80 people viewed this question
 Grubhead
Grubhead
