Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
Dual fuel kithen aid F 02
My KDRP407HSS left set temp and sky rocketed, the door locked, and the contents of the oven burned. The code F 02 was on the display. One other time recentley the oven just turned off. Any ideas!
  • 5 more comments
  • Anonymous Nov 06, 2008
    Same problem ... no effective help from Whirlpool Corp ... They sent a tech who turned on the oven, sat around for 20 min and declared "no trouble found". Sounds like its a common problem.
  • thartje Nov 23, 2008
    I just experienced the same problem and am looking around the internet to find out what’s the problem. I caught it in time not to burn dinner, but the only to turn the oven off was to disconnect the electrical power.
  • tkobie Dec 23, 2008
    1. Wife turned on oven to pre heat and when came back oven over heated and locked up, Up able to reset and had to turn off electric (CB) to range to cool down as smoking very heavy. Now only get f 02 when power turned on.
  • runnersinc Feb 19, 2009
    my cheesecake is ruined! exact same problem: random switch to clean and now i have F 02 -- how do i fix?
    exact same problem! random switch to clean function, burnt cheesecake and F 02. frustrating!
  • Anonymous Feb 24, 2009
    Same problem - disconnected the power... now I am waiting
  • kmfn Apr 15, 2009
    This is the fourth time we've experienced high temps, smoke, a locked door and the F 02 code. This time the handle on the lid of my LeCreuset exploded, which BTW was on the lowest shelf with the oven set at 315 degrees F. After the second time KA suggested we stop using the stove until factory service appeared, and recommended that we not only disconnect from power source but also turn off the breaker. (???) A&E Factory service ordered eight parts and charged for 120 minutes of labor with the total cost accumulating to somewhere over a thousand dollars. Since it was still covered by warranty and the receipt only shows asterisks in place of the numbers I don't know the actual costs. Now two years later we're back to square one, but when I last called KA service they claimed the unit wasn't their problem and that they'd never consider one of their units as a lemon. Factory service has visited us seven times in less than five years for this unit alone. We also purchased a KA dishwasher model number KUDPO1FLSS and have experienced numerous problems and repairs. These units have easily cost KA and the warranty company more than the original purchase price of the product and warranty combined. I saved the receipts with a list of the parts ordered but haven't a clue as to which parts were utilized since they didn't replace all parts. We will NEVER purchase KitchenAid again, and since it was made by Whirlpool we have reason to question the quality and reliability of their products.
Welded element relay on the control board.
Brian
Posted on Apr 18, 2008
Error code FO5...oven dead
Duel fuel? Which one does the self-cleaning? I'd bet electric. If so, the gas mode must not be used, and it may be telling you that.
Apr 10, 2015 | KitchenAid KDRP407HSS Dual Fuel (Electric...
OVEN GLASS INSTALLATION
MODEL #TES356TD SERIAL RWO0415338 ESTATE
Jan 17, 2014 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Kitchen Aid dual fuel oven, getting an error message F 02
F2
Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this
happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN
models: check door lock operation.
3. Look for a high resistance connection
or any other cause of high resistance in the oven temperature sensor circuit.
Check sensor, sensor harness and sensor harness connection at sensor and oven
control. Replace sensor if found defective.
Remember: Oven control
(ERC) measures resistance of sensor circuit, not actual oven
temperature.
Jan 02, 2011 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
How do you use the self cleaning option for Kenmore dual fuel ove
Simply press the "Clean" button and set a time (Hi or 4hrs is best) it will the lock the door and burn everything inside. If you have silver colored shelfs remove them fist. After its done and has cooled wipe out the ash that has collected in the bottom of the oven.
Dec 27, 2008 | Kenmore 75503 Stainless Steel Dual Fuel...
KDRP407HSS oven door adjustment
I found a solution. Remove door (very simple procedure listed in Use and Care Guide). Make a shim and attach it to the end of the hinge arm (the part of the hinge protruding from the door that goes into the slot in the frame). I used metal shears and a coffee can and made a metal strip that I wrapped around the arm 3-4 times. Reinstall door and it should be tight at the top. (Unfortunately I suspect this fix will be temporary until the ill-designed hinge mechanism starts bending again.)
Nov 12, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
RE: f5 fault code; kdrp407hss
Solution!!! The hinges that Kitchen Aid uses are the problem. If the door is opened quickly & bottoms out, the steel in the hinge bends a little. So when you go to close the door it won't close all the way.... which causes problems with the latch , latch switch, oven cleaning, etc.
After taking apart the door several times I realized the hinge can be "fixed" without even removing the door. Follow the directions in the user manual for door removal... after inserting the little metal hinge stops (a drill bit or nail will work) Close the oven door till the stops won't allow it to close any further.....then gently but firmly, push forward. This will bend the hinge back to original shape. Remove the pins...Voila!!!
I wish kitchenaid used hardened steel or a thicker hinge....then this wouldn't happen.
Nov 11, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
917 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
