Question about Car Audio & Video
Car runs fine then all of a sudden the check engine light comes on and car starts acting like it's running out of gas..bucks and loses power. You can restart and sometimes it is almost like something clears and it runs fine. we had the feul pump replaced last year and it used to do it only on the highway when it hit 70 and it was very sporadic...almost like a cough. Now it's worse. could it be a clogged feul filter?
  • 3,083 Answers
It's very possible that the fuel filter is jamming up, and I'm surprised they didn't change it when they replaced the fuel pump. I would get it changed first, then see where you're at. You can get a lot of car codes read for free at Autozone, in case you haven't done that, if the vehicle has a car code computer. Check your manual, since sometimes you can force the codes yourself.
Also, if the car has a metal timing chain, it can be slipping (had those same symptoms in a car years ago). It can also be faulty wiring to the fuel pump. If you can get the check engine light code read, it might lead you in the right direction. Hope it's just a jammed fuel filter, they do that every now and then.
Posted on Jul 06, 2010
  • 1,284 Answers
Hi, you actually guess right, you are having a clogged fuel filter, so it intermittently bucks when there is no supply of fuel to the engine and definitely looses power. You need to change the fuel filter immediately.
Take care
Suddenly loses power no noises coolant light and temperture light comes on
probaly lost fuel pressure, from fuel pump going out, or relay went out. Need more info such as, did engine stop running completly, or did it start back up etc. post back please.
Mar 09, 2014 | 1995 Oldsmobile Achieva
1997 lose of power when the a/c comes on
On small engines, any minor performance problem is amplified with the ac due to the horsepower the compressor pulls.
You probably have a spark plug miss or injector problem that is made worse with the ac on.
If you have not done a routine tune-up on the car I would do that first, along with replacing the fuel filter if equipped.
I assume the check engine light has not come on right ?
Jul 26, 2012 | 1997 Dodge Neon
I have a 2000 buick Lesabre and was driving home from work, 30 miles later at a stop light the engine started losing power. Started like sputtering.... it cleared up and was fine another 6 miles and...
have the coils and control module tested, sounds like you lost a coil so it not firing on all cylinders, it puting gas into nexhaust thats the smell, have it checked asap so you dont damage converter, hope this helps.
Dec 20, 2009 | 2000 Buick LeSabre
Car has half tank of gas acts like its run out of gas until more
is there a engine light on? take the gas cap of and see if it does better you might have a plugged vent
Oct 28, 2009 | 1997 Dodge Ram 1500 Club Cab
My has no power when i give it gas
Has the service engine light come on?
Does this happen when it rains or when it is damp?
Let me know.
Regards,
Jun 18, 2009 | 1997 Chevrolet Camaro
97 jeep wrangler 2.5 running lean
check fuel pressure and check exhaust for leaks. exhaust leaks caqn play with the o2 sensor readings
Sep 15, 2008 | 1997 Jeep Wrangler
"99 cherokee classic: sputtering when cold
I had the same problem with my 99 Cherokee. I was told to replace the blower motor for the carburetor, works great and gas mileage improved.
Jul 16, 2008 | 1999 Jeep Cherokee
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
