Question about Landice L7 LTd Pro Sports Trainer Treadmill
Treadmill does not start
The screen is indicating "L5". i have tried unplugging and restarting, but unit does not move. please help. thx
  • 79 Answers
Is a problem with the speed sensor or card connectors are specifically where the motor cables is false or welding is damaged if you can not check you should call a qualified technician to review these two parts and repair.
Posted on Sep 14, 2010
HI our Bowflex series 3 treadmill is giving us a continued Err L5 code when trying to use our machine. We bought it used so do NOT have ant trouble shooting instructions. Any advice?
Hi There, L5 error should refer to the "LS" error which looks up to a speed problem. When you start the machine up, it boots fine and then when you press start or go is says err ls ? If the walking belt doesn't move at all when you try to start it, listen for a "Click" on that lower board when start is pressed..... If the walking belt moves for a second and then stops and the console says err ls, then you may have a speed sensor problem. These control boards are repaired by Jatinah Electronics who can be found with a google search. Good Luck!
Dec 13, 2016 | Bowflex Exercise & Fitness
My bowflex treadclimber starts for abut 3sec then err L5 shows on the screen PLEASE HELP!
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
Jan 22, 2011 | Bowflex Treadclimber
When turn on, the screen just shows a red background with the iFit logo. Can't even get to the star menu
I would first try resetting the treadmill by unplugging it for 30 minutes and trying it again. It sounds like a software issue and unfortunately, the firmware isn't public so please call 800-999-3756 (6 A.M to 6 P.M. MDT) or email service@iconfitness.com during the week and a service technician will be able to further help you. Let me know if you need anything else.
Benjamin
Nov 06, 2010 | Nordic Track NordicTrack COMMERCIAL 1750...
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Feb 12, 2010 | Landice L7 LTd Pro Sports Trainer...
Belt does not move panel lights up
Does your L7 have error code that looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Feb 07, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Describe your Spirit ® XT275 Folding Treadmill Problem - serial number 90488105100032rev-00 I started the treadmill as I normally do by pressing the start button. The belt does not move. I think...
Hi
Thanks for using FixYa. Please read this out:
How to Troubleshoot a Treadmill
If still the issue is not resolved then you can contact local repair center.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 05, 2010 | Spirit ® XT275 Folding Treadmill
Motor does not run belt
place a regular 9 volt battery to the motor wires with the unit unplugged from wall and see if it moves. if not it's the motor, if so it's the lower board. we can help with that @ www.nashsfitness.com
Aug 09, 2009 | Proform XP Weight Loss 620 Treadmill
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
Landice L7 LTd Pro Sports Trainer Treadmill Logo
325 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Sportsmith LLC
Sportsmith LLC
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
