Hi, i have a panasonic 50" hd plasma flatscreen. Its a viera tx-p50g10b model. It has a power-up fault with either the SC, SD, or SU board being the problem (standby light blinks 7 times). I now have another used one with a smashed screen which i have bought for spares. I am comfortable with fixing things myself but have not taken a tv apart before. Please can you tell me if there is a video available or even diagrams or photos available showing these boards? I have been instructed how to check which one it is that is faulty once i open the back (remove connections between one board from other 2 and check) but do not know how to identify the boards. Many thanks, sam.
  • Ku-pac Jul 06, 2010
    Great help! thankyou
  • 484 Answers
First, to take apart the television is not a problem. All you need to do is to get the appropriate screwdriver, unscrew the television from the back, and you will have access to all the components inside the television.
To know which part is the you can tell from the, it will be written at the back of the board.
The image of a sc board looks like the image below;
hi,
The image of a su and sd board looks like this
Hope this helps.
Take care
moz-screenhi,
Posted on Jul 06, 2010
How do I fix my Panasonic Plasma TV?
Call in a repair specialist. You have done everything you can do.
Nov 18, 2015 | Panasonic Viera TC-P50S2 50" Plasma TV
What does 7 red blinks mean?
7 blinks of standby light to Panasonic brand Plasma TVs means; Driver SOS 2 SU / SD / SS Boards (SC floating voltage area). If you wish to get more details about the blinking codes and faults to Panasonic Plasma TVs, check this site. There is explanations with illustrations to many faults to many brand TVs, including Panasonic. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 28, 2013 | Panasonic Smart Viera 50 Class UT50 Series...
I have the 50 inch panasonic for only 12 months and have red light blinking 7 times
Hi, one of three boards are the culprits. SC, SU and SD boards. (Y sus and the drivers). Possibly but very very rare, the panel could have blown those boards out.
Apr 10, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Just bought panasonic th-42x20k, when turn on hear a clicking sound and then turn off, red light under screen flashing 7 times
Red light flashing indicates that "SC voltage is floating". I'd recommend replacing the SC, SD and SU boards. Also know as the Y sustain (SC), Upper and lower buffer boards (SD, SU).
I suggest you contact your local Panasonic Service Agent as parts are only available from Panasonic and are quite expensive.
Jan 18, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Hi, i have a panasonic 50" hd lcd flatscreen. It has a power-up fault with either the SC, SD, or SU card (standby light blinks 7 times). I now have another used one with a smashed screen which i...
The SU, CD, SD cards are located in a plasma(The are the sustain boards of a plasma) not an LCD tv if I am not wrong. If you have purchased the LCD tv then you should replace the power supply board that seems to be the source of the problem. It is the board into which the power cord goes. You should make sure that you have turned off the set and unplugged from the power outlet before you attempt to remove it. You may also want to discharge the caps by placing a bulb(preferably 60W or above) on the solder leads of the capacitors.
Jul 06, 2010 | Televison & Video
Power light flashing
if flashing 7 time need replaced sd board and su and sd board
Panasonic TXNSD1RJTU SD BOARD BOARD, SD (Y SCAN DRIVE LOWER ASSY)
Panasonic TXNSU1RJTU SU BOARD BOARD, SU (Y SCAN OUT UPPER) ASSY
Panasonic TXNSC1RJTUS SC BOARD BOARD, Y SUS DRIVE BOARD
Jun 03, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
7 blinking Red Light. Power Supply problem??
Need replaced su.sd and sc board
Panasonic TXNSC1RKTUS SC BOARD BOARD, SCAN DRIVE ASSY
Panasonic TXNSU1RKTU SU BOARD BOARD, UPPER SCAN OUT ASSY
Panasonic TXNSD1RKTU SD BOARD BOARD, LOWER SCAN OUT ASSY
Dec 09, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
