Question about Maytag SDE3606A Electric Dryer
Dryer will not come on or anything. - Maytag SDE3606A Electric Dryer
  • Maytag Master
  • 3,051 Answers
Hello there:
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing.
Posted on Jul 06, 2010
My westinghouse dryer turns on but only beeps at me and doesn't do anything
Is it electronic unit or older unit
Check door switch and the motor,belt
Apr 01, 2015 | Dryers
Blower wheel bad on may tag dryer
anything involving gas have a certified technicien to do it,anything goes wrong your safety is at risk
Feb 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Amana electric dryer whining when started
Is ther anything caught between the drum and the back of the dryer. run you finger around the back edge of the drum inside do you feel anything caught
Feb 02, 2014 | Amana Dryers
Samsung dryer without power
What is the model number??
Jun 27, 2013 | Samsung Dryers
My whirlpool duet dryer will not come on will not beep or anything
no power at plug check house fuse box or bad heating element will cause dryer not to function.
May 10, 2012 | Washing Machines
Dryer working fine, in middle of a load it just died. No power to anything. Touch screen does not display anything. Interior light does not come on. Checked the house breaker and it is fine. Unplugged...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 23, 2011 | Dryers
Dryer wont heat
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Mar 01, 2011 | Frigidaire FER231A Electric Dryer
Model 87577800 sock went thru the lint vent
The model number you have listed has the dryer vent on top of the dryer. Small items commonly fall down into the vent chute on these dryers. Articles can easily be retrieved by following these steps:
1. UNPLUG the dryer. Dangerous voltage is still present inside a dryer even when it is turned off.
2. Remove the lint screen and remove the two screws that connect the vent chute to the top panel.
3. Turn the dryer around so you can access the rear, and remove the exhaust vent hose.
4. Locate and loosen all the screws from the perimeter of the dryer back panel.
5. Remove the back panel of the dryer.
The air blower assembly and dryer vent chute are located on the left hand side (as viewed from the rear of the dryer). Remove the screws that hold the vent chute in place and you will be able to access anything that has fallen into it.
NOTE: Anything left in the vent can eventually get caught in the blower fan. So, it is important to retrieve anything caught in this area to prevent damage to the fan and to ensure the dryer ventilates properly.
If you have any questions about these procedures, please let me know. I hope this helps you.
Oct 27, 2009 | Dryers
The gas dryer won't stay heated up.
Do you have stacked clothes on top of it or anything else? If so remove those items and never put anything on there. it's not a table it needs to be clear so heat can dissipate from cabinet. IF that doesn't solve it write bac
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Maytag SDE3606A Electric Dryer Logo
100 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
