We own a Whirlpool front loading washer. The machine always has some 'left over' water in the machine. When we haven not used the machine for several days and we do a load of wash, the water which comes out of the drain tube into our tub is stenchy and smells like sewer water. If we do a second or third wash, this smell does not occur. It seems to be when this water stands in the machine or drain lines. How can we correct this? Can I run the cycle with no clothes in it with a bleach compound or something to kill this odor (a bacteria????). Please advise.
    Problem Solver:
  • 5 Answers
This does not apply to only Whirlpool Duet washers
Bad smells and spider corrosion in front load washing machines.
When all other remedies for curing bad smells coming from front load washers have been tried and have not been found satisfactory I believe the source of the smell may well be corrosion of the aluminium spider with the products of this corrosion harbouring 'water' that turns foul as described below, or, should no corrosion have occurred the 'water' left in the recesses of the hubs of the spiders will, if left long enough, turn foul.
Aluminium, and its alloys, are corroded when immersed in an aqueous solution with a pH value below about 4.0 (acidic) [nitric acid is a well known exception] or above about 8.0 (alkaline), most laundry aids, detergent including HE detergent, borax, bleach (sodium hypochlorite), sodium carbonate (washing soda), sodium percarbobante (found in Affresh and OxiClean), sodium hydroxide, Affresh and OxiClean can have pH values above 8.0 should the required concentrations be reached. At the normal operating levels found in washing machines these values are not exceeded. However when the machine is shut down any water remaining will contain, inter alia, soil from the laundry, products of the interactions between the soil and the laundry aids used, unused laundry aids, and the chemicals found in the tap water. As the water from this mixture evaporates the concentration of the 'impurities' rises until such time as a 'smelly sludge' develops and/or a pH level above about 8.0 is reached and corrosion occurs.
Prime areas for these deposits to occur are, in my opinion, the recesses found at, or very near, the hub of some of the aluminium alloys spiders found in front load washing machines. The final spin, no matter how fast, will not, in my opinion, remove all the 'water' from theses recesses.
To view a corroded spider (not to the point of catastrophic failure) and one with a build of 'smelly crud' please visit: -
http://www.ripoffreport.com/appliances/electrolux-home-prod/electrolux-home-products-n-am-4cd6d.htm
These spiders were removed from Frigidaire built 'Kenmore' machines.
To see fractured spiders from Frigidaire built machines, Whirlpool 'Duets' and other manufacturers' please visit: -
http://fixitnow.com/wp/2009/10/28/front-loading-washer-corrosion-contagion-a-menagerie-of-metallic-misery/
Or, for a Whirlpool spider
http://www.mysears.com/aboutme/jpm0940
Not all manufacturers use spiders with recesses, Speed Queen do not (Speed Queen call them trunnions) and photographs at: -
http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?30834
show Miele spiderss without recesses. There may be others.
Posted on Dec 01, 2010
  • 145 Answers
Yes you can run bleach through it on a hot load and that will help. Whirlpool reccommends a product called whirlout. It's made to clean whirlpools. But I use bleach and a little powder cascade dish detergent on a long hot wash to clean out the inside of the tub and pump.
Posted on Apr 18, 2008
Whirlpool front load washer. Front seal keeps filling with water .
Today front load washing machines always causes problems, so get a repair man or else it's always best to clean it properly.
Mar 22, 2017 | Whirlpool Washing Machines
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
Why does my new whirlpool washer wtw4950xw2 cause clothes to smell musty? I also noted when shaking the tub after load is complete, water sound is audible, although tub is empty. Could there be a check...
This machine is a lemon It will break down in a year or less. I have the same machine. The gear box, motor, and now the control board went bad. I haven't been able to use it for 2 months now while they try to fix again & again
Oct 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Do you need to keep the door open when not being used. i know some models require that.
There's no special requirement that you need to keep the door open. But, If you keep it closed after your done washing, some water is usually left behind and if you don't wash for a few days it could make the first few loads have a certain musty odor. I always leave the door open for a few days to dry out the insides then close the door and I haven't noticed the musty smell. Good luck.
Apr 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool awm8143 model front loader. works fine
this could signify that you have the outlet hose to far down the outlet pipe of the machine, or if you have it plumbed in to the plumbing under the sink you could have dirty sink water flowing back into the machine
Mar 02, 2010 | Whirlpool AWM8143 Front Load Washer
Clean the washer using the AFFRESH wipe down after use and when we wash again the washer puts out a smell what up?
the smell comes from the fabric softener people use,put the machine through a hot water cycle and use CLR in the detergent dish,and after your done the wash always leave your door open on your front load so it can get air
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water filling up in Front loading Whirlpool washer
sounds like you have a faulty water valve that does not close when the power is not supplied to the machine.or a problem with the cotrol board supplying power to the valve when the unit is not in use
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Load Washer
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
