Question about Cameras
Canon HF200 does not read firmware on DW-100 canon buner gives HF200 display can not read disk
  • 8 Answers
SOURCE: canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Posted on Dec 19, 2008
SOURCE: Canon DW-100
yes you can play a DVD burned with the DW-100 in Hi Def as long as you are using a DVD player that supports AVCHD format which is what the DW-100 burns. Most Blu-Ray players will support AVCHD.
Posted on Jan 18, 2009
  • 50 Answers
SOURCE: Canon SX 10 IS firmware version
first make a file and name it "ver.req", then copy it in root of your memory useing a card reader;
then use func+disp, now open the file in computer(with notepad)... just this!
I hope this helps...
Posted on Mar 24, 2009
  • 102366 Answers
SOURCE: I cant work out how to burn a DVD using the Canon
If you just want to back up files by storing them on a DVD, do that by using whatever your operating system provides. Since you didn't specify the type of computer (Mac or PC), I can't tell you how to do that.
If you want to put videos onto a DVD so you can watch them via a DVD player, that's a completely different thing. For that, you will need DVD mastering software. Again, the possible choices vary according to the type of computer and the operating system.
Posted on Feb 01, 2010
SOURCE: Canon DVD burner DW-100 and HG10 burn issue
You can not have any MXP Files in your play list or in memory. The DW-100 Can not burn these files. Once you delete/remove the MXP Scenes from the the Camera the Burner will work fine.
Posted on Mar 05, 2010
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
I am thinking of buying a Connon VIXIA- HF-MA300. Will the DW-100 burn directly from the camera ?
Connect the camera to your PC.
Connect the Canon burner to your PC.
Use free software (see: http://www.MajorGeeks.com and search for "AShampoo Burning 6")
to read the files from your camera, and burn them to a blank CD/DVD disk.
Dec 12, 2010 | Canon DW 100 DVD-RW Burner
The Burner does not read the discs.
try a firmware update and then if it still dosnt see the disc make sure if its old to check inside to see if the laser maybe out of set. and or a bad diode laser.
May 27, 2010 | Canon DW 100 DVD-RW Burner
Cannon DVD Burner DW100
I had this problem also when trying to connect to my HF200. I found a solution. The DVD recorder does not like MXP recordings, in fact it hates them. You will have to make sure no MXP recordings are present on your SD card/Hard drive. Then any recordings you make with the intension of recording to DVD need to be made in FXP mode or below. But remember if you have a selection of recordings on your SD/HD and just one is in MXP mode, you will get the error 'Operation cancelled'. Just as a sidenote, I phoned canon support about this problem, they were useless, promised me a callback that I never got!
Feb 01, 2010 | Canon DW 100 DVD-RW Burner
Dec 13, 2009 | Canon DW 100 DVD-RW Burner
I have connected the DW burner to my camcorder but it does not recognize the disk. Indicates check disk Please help
u should have a cannon camcorder because this device works with a compatible cannon camcorder.
Aug 29, 2009 | Canon DW 100 DVD-RW Burner
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
Canon DW-100
Thanks, I think it works that way. gl
Dec 08, 2008 | Canon DW 100 DVD-RW Burner
Cameras Logo
99 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
