Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Drive belt broken is it worth replacing it? Other parts OK
Is it worth changing drive belt
  • 518 Answers
The cost of the replacement belt is cheaper than a new trimmer so has to be worth changing
Posted on Jul 07, 2010
Bosch dryer has heat but does not spin
Either the belt has slipped off or broken, or the motor start/run capacitor has failed.
Place the dryer on its face, with cushioning. Take off the back panel and look around inside. You will see the drive belt which is long and thin and should wrap around the drum.
http://pad1.whstatic.com/images/thumb/2/27/Change-a-Clothes-Dryer-Belt-Step-12.jpg/550px-Change-a-Clothes-Dryer-Belt-Step-12.jpg
If the belt is broken, replace it. If it looks OK, find the motor start capacitor, which looks like this. A failed capacitor will have a split or bulging case, or a displaced end cap. They are widely available on eBay or from appliance parts shops. Get one the same voltage and capacitance rating, eg 240 VAC and 8 uF or whatever.
http://www.capacitorguide.com/wp-content/uploads/motor-start-capacitor-300x212.png
Sep 02, 2013 | Dryers
Self propel not working
Make sure the replacement belt was the right one/size.
Make sure the self propelled is on at the handle. If you replaced the flat belt and it still pushes hard the most common problem is a broken power drive cable or actuator arm. Put the handle down and move the power drive handle forward and backward. If it moves freely watch by the headlight for the cable to move the actuator at the base. If the cable is in tact it should move the actuator. If it is broken the actuator will not move. If the actuator is broken the piece of plastic holding the cable will let the cable slide or it may be broken off completely. Replace whichever is broken.
If the cable system is ok and the belt is correct you may have a bad powerdrive assembly. I will include links to correct replacement parts.
Actuator
http://www.vacuummedic.com/product.php?id=363
Cable
http://www.vacuummedic.com/product.php?id=362
Belt
http://www.vacuummedic.com/product.php?id=6
Good Luck!
Aug 23, 2012 | Hoover U6446-900 WindTunnel Bagged Upright...
Need part for Mastercraft belt sander 54-7240-8 I need to replace the belt on the motor that drives the belt drive assembly. The motor runs ok but, the wheel that drives the sanding belt doesn't turn...
Anyone has a broken belt sander 54-7240-8 within Canada? I could use a particular part from it to fix mine. If you do, email me at mstevlik@zoznam.sk
Thanks.
Sep 27, 2011 | Tools & Hardware - Others
Serpentine belt routing for 2001 ford taurus
what engine? Please rate if this helps. Took a lot of time to dig out.
here's 2002 3.0L 2 valve
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
4 valve
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
water pump 4 valve
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8509 Water pump pulley 4 8W508 Drive belt tensioner pulley
Dec 20, 2010 | Ford Taurus Cars & Trucks
Ac belt broken. Is car safe to drive? How hard is this belt to replace?
as long as the water pump, alternator, are working properly. but if it has just one serpintine belt that drives all things it must be replaced. before running. if only the ac belt, it is ok to drive if it has its own belt that is broken.
Aug 13, 2010 | 1995 Isuzu Rodeo
Changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Jul 25, 2010 | Roper RTW4100SQ Top Load Washer
Murray riding mower broken drive belt .. only part number I find is 30570x8c date code 3362 .. can't find a part number on the belt and the murray website is totally unhelpful
take the broken belt to your nearest small enging repair shop and tell them you need a belt thats the same size as the one you will hand him.. if he sells belts he'll have the one you need... good luck
Apr 05, 2010 | Garden
My HP Deskjet ink drive belt has broken, where do I find a replacemnt?
It's quite difficult to get a belt replacement. When I need one, I go to the flea market or Good will stores to buy a broken printer with a belt in good condition. I usually pay 5 to 10 USD for a printer that I'm going to use for spare parts. Sometimes I also get a working cartridge worth of $15 USD with the printer.
Dec 22, 2009 | HP DeskJet 895cxi InkJet Printer
Teac X-1000r broken drive belt
Gidday Chino
You can get a FRESH belt kit from here. Cost you $10 plus some post. There is a new pinch roller listed against this old girl also could be worth replacing at the same time when you service the deck.
regards
robotek
Aug 05, 2008 | Audio Players & Recorders
Cd tray eject problem
THE DRAVE is DAMAGED
the carriage unit (tray) is braoken, you can open it up and use plastic weld to fix the broken off part or you can change the tray or buy a new one :)
Dec 22, 2007 | Samsung (DSSMBK482448) CD-RW Burner
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
412 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
