Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
Making and dropping ice, but not retaining ice...evidently melting...feels cold, but no accumulation. Is the white tube hanging down supposed to be connected to the drain line in the bottom?
    Problem Solver:
  • 7 Answers
Yes to drain line. Clean the condensor and evaporator first. Check the spray jets to see it they are clogged. There is a screen on the inlet water valve as well. Check door seals and cabinet tight.
All else fails look for oil around the hot gas valve.
Posted on Aug 23, 2010
Ice cube maker and fan has stopped working in the freezer section,and ice has started to appear half wY up the freezer section,can anyone help?
Ice accumulation may or may not be related to the failure of ice maker and fan. If the fan has simply failed, then frost will build up as a result of cold air not being circulated in the freezer. If there is no evidence of physical impedance such as accumulated ice blocking operation of the fan; remove the fan, check function outside the unit and replace the fan if it does not work when you apply AC. Avoid electrical shock!
The major cause for ice appearing in freezer: When the defrost cycle begins, the freezer elements are heated to melt accumulated frost. If the melt water is blocked from draining, ice will build up from repeated freezing and melting, thereby decreasing functionality to the point of complete failure. You must find the blockage and remove it.
Blockage is from food particles which have entered the drainage tube and failed to pass to the evaporating pan located in the area of the compressor which from the heat of the compressor allows drainage water to evaporate. The principle is simple and direct, but accessing the components to remove the blockage without permanently damaging the fridge can be frustrating, and will be messy dealing with accumulated ice while the contents of the freezer you placed on your kitchen table are defrosting. Removing ice is best accomplished by melting it with a good hair dryer. Big towels, water collecting pans, patience and extreme persistence are also required. You will be amazed at the amount of ice you will be dealing with. Unplug the fridge and do not chip at the ice.
If your unit is still under warranty, do not hesitate to call for repairs. When the service person attends the problem, watch carefully, note the sequence of operations, closely observe his or her technique, because this will happen again. Clearing this ice can cost you $300 or more each visit.
Some designs have called for a restricting nipple located at the end of the tube supplying the evaporation pan. This serves to impede the tiniest of debris inside the tube, progressively freezing the blocked water up to and beyond the drain located under the freezing fins then into the freezing compartment itself. Remove that nipple! Your repairman will not remove it because it voids the warranty if you still have one. The nipple is there to assure the industry you will be buying another $2000 unit soon.
My first fridge lasted 37 years before I decided to purchase a new one due to increasing inefficiency. I unblocked its drain tube twice in those 37 years. There were no restricting devices. The particles were simply inevitable chunks which got caught over time and unlike modern units, were easy to access. That unit was a large GE frost-less, We were careful through the years to keep dust from the condenser coils..... so we thought. When I got the unit into the yard, I tipped it forward to discover dust impacted around the 18 inch condenser coil stack inaccessible when the fridge was in the kitchen. A high pressure water source was required to blast away that densely compacted dust. After the unit dried, I plugged it in and the efficiency was as good as new, but I already had a new unit filled with food, standing in the kitchen where the old GE once stood. Despite that, the new fridge uses only an average of 30 watts continuous power, cutting my electric bill in half, paying for itself in saved power consumption over three years.
Regarding the new unit, I had to clear the melt tube twice. First time under warranty, second and last time after I fixed it. My brother bought the very same unit, having refused the expensive extended warranty, called me about two years after purchasing it mentioning ice accumulation in his freezer. I told him what to do over the phone. He bought me some beer.
Jan 20, 2016 | Refrigerators
My Whirlpool refrigerator, model GT22DMXGW00, leaks. Water is accumulating in the bottom-underneath the right hand side crisper. It then drains out onto the kitchen floor. Some is freezing too. It is...
check the ice door flap where ice drops into a glass.sometimes the flap doesn't close completely and allows heat to enter threw the flap.this causes frost to build and melt thus you have water you can't explain. hope this helps.
Dec 11, 2014 | Whirlpool Refrigerators
Inside rear panel bulging
Unplug the unit and take out all the drawers and remove the back (behind the drawers) panel carefully. (This back panel has foamy thermal insulation behind it and this will be probably be enmeshed with ice - you may have to wait awhile for this ice to melt before you can remove the panel, even after you have unscrewed it.
When you have got the back panel off, you will see a large solid block of ice, probably halfway up the cooling coils, right down to the bottom of the exposed space. You have to melt all this ice (I used a hair dryer to blow warm air onto the ice (have towels and a bucket ready to mop up the melted water, otherwise it will run over the floor. When you have melted all this ice, you will see a drain hole at the bottom of the exposed space. This will have ice in it and it must be cleared.
Then replace the back panel and all should be OK.
The panel bulges because ice/water is accumulating behind the panel, water, when it freezes, expands, forcing the panel forwards.
I reckon it's a Hotpoint Design fault. What is supposed to happen is that during the heating cycle, melted ice drops down from the cooling coils and down the drain hole onto a plate over the compressor unit, where it evaporates. BUT, during the cooling cycle, a fan circulates cold air from the cooling coils, through the entire unit, which includes the chamber behind the panel that is below the coils. Thus this chamber gets cold (-18 deg.C) so that water dripping down during the heating cycle is frozen before it has a chance to fall down the drain hole.
I now defrost in this manner every six months or so. Sadly, very sadly, Hotpoint, like other white goods manufacturers (Baxi Potterton boilers for instance) do not reply to my enquiries.
Hope this helps.
Feb 19, 2013 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
My KTRC22E kitchen aid refrig. stopped making ice. I replaced the valve that ties into ties into the cold water line. The drinking water in the refrig is working properly. I'm told it may be th
sounds like you have a problem with the fill tube at the Ice Maker. remove the IM and then the back wall ( evaporator cover ) , the fill tube is probably frozen. use a hair dyer to melt ice, be careful, the hair dyer can melt the fill tube and other plastic.
Jan 07, 2012 | KitchenAid KTRS22EM Top Freezer...
Hi - My refrigerator has begun making a very loud noise - like an airplane engine - when it kicks on. After a few minutes the sound recedes but is still louder than normal. The bottom freezer is way too...
it sounds like ice built up arounnd the fan blade probably from leaving the bottom freezer door open and warm air got in and froze up the air ducts or you have a defrost problem but if you hear a cracking sound it sounds like the heater is coming on but can't melt out all the ice.try this,take out all the food out of the freezer,unplug it,get a hair dryer and blow the hot air at the back wall where the vent holes are and melt out all the ice,when you look into the vent holes and don't see anymore water dripping down you can plug it back in and with your hand feel to see if you can feel the air blowing into the fridge section,if you feel the air then you melted out the ice and if the noise is gone then the evap fan motor is still good,if there's alot of ice and snow on the back wall you should remove the panel and then melt out all the ice with the hair dryer.also if you have another fridge you can unplug the fridge and let it melt out on it's own for like a day
Feb 10, 2011 | Refrigerators
Seems to make ice but will not keep it cold therefore it melts. It does this about 3 or 4 times a year but after staying off it will start working again
The only thing that keeps the ice cold is the ice itself. If the icemaker isn't making ice fast enough then the ice will melt before more ice drops to keep it cold. In other words the motor ice the slower the ice melts. Now if the door gasket isn't sealing properly then the ice could melt to fast. Also the ice is going to melt some and when it does the water has got to drain out the bottom. If the water doesn't drain the ice will be sitting in water and will speed up the melting process dramatically. I hope this helps!
Sep 28, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Viking under counter ice maker stopped making ice... ugh.
This unit senses the "freeze plate" temperature to decide when to go into "harvest". Either the the temperature sensor (most likely called an evaporator thermsitor) is lying to the control or the plate is not getting cold enough due to a sealed system issue (usually a bad hot gas valve). If you carefully loosen the front grill (staying clear of the wires going to/from the ON/OFF/CLEAN switch) you can see the hot gas valve near the center in the bottom of the mechanical area. If the copper tube coming out of the bottom of the valve is cold during the freezing cycle...it is bad. If not, I would try the thermistor first. If you do not feel comfortable doing this, you should contact a servicer to diagnose the unit for you. Good-Luck.
Apr 25, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Build up of ice on bottom of LG fridge freezer
See details athttp://www.fixya.com/support/t1492965-lg_frost_free_fridge_freezer_gr_399sq
I had the same problem - took out the back panel.  Some firm pulling is required as there is a clip just below and to the right of the lower screw as well as some small retaining 'bumps' on the side and a pair of 'dragon's teeth' retainers at the top.  Pull at the bottom and let it drop down.
Took out the next panel - after defrosting at the bottom with a hair dryer - clips on side near bottom and encourage it to drop down a little and unplug fan unit.
Bottom tray was solid with ice - hair dryer again until drain hole was cleared to allow melt water to discharge into tray below heat exchanger in the rear compartment for evaporation.
There appears to be a U-shaped heating element - 4 ohms - below the freezing coils.  Presumably this is intended to melt any ice.  I suspect that this may not be operating efficiently if at all.
As it took about 8 years to get into this state, I propose to check that the outlet into the back is free every year or so and defrost if necessary
Mar 15, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Ice cube maker
IF NO WATER IN ICE MAKER, CHECK FOR RESTRICTION IN FILL TUBE SUCH AS FROZEN OFF WITH ICE. REMOVE FILL TUBE AND RUN HOT WATER OVER IT TO MELT ICE IN TUBE.
WATCH FOR WATER COMING SLOWLY OUT PLASTIC FILL LINE ATTACHED TO TUBE ON BACK OF REFRIGERATOR.
IF WATER SLOWLY DRIPS OUT OF FILL LINE, REPLACE FILL VALVE( LOCATED WHERE HOUSE WATER LINE ATTACHES TO REFRIGERATOR.
IF ICE MAKER HAS WATER/ICE IN IT, PULL FRONT COVER OFF ICE MAKER TO ACCESS CONTROL HEAD. INSPECT LARGE WHITE GEAR ON FRONT OF CONTROL. IF THE RETAINING TAB IN THE CENTER IS BROKEN, REPLACE MODULE OR ENTIRE ICE MAKER. THERE SHOULD BE TWO
RETAINING TABS HOLDING THE GEAR IN PLACE.
THE FREEZER TEMP NEEDS TO BE A MINIMUM OF 10 DEGREES FOR THE ICE MAKER TO CYCLE. IF THE FREEZER TEMP IS NOT COLD ENOUGH WE WILL NEED TO FIND OUT WHY.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
297 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
