I changed the hard-drive from 10g to 250g and I need to install the programs that came with the system, but I tried to do it and it didn't work. How can install the programs? I already have the Windows XP64. I don't think it works on the system.
    Scholar:
  • 36 Answers
You have not mentioned what model of laptop this is.
And keep in mind that there are ways to copy the 10GB drive directly to the 250GB drive, so you dont have to reinstall anything.
Checkout DriveImage XML http://www.runtime.org/driveimage-xml.htm. or CopyDisk http://www.easeus.com/disk-copy/ both free.
Otherwise check for drivers and system utilities from the manufacturers support page, and for things like MS Office you will need the original install disks and product keys.
Posted on Jul 06, 2010
How do I record programs from tv
usually we would do this with a dvr recorder . which is a separate unit . do not think there is a way you can do it directly to a computer .or a thmb drive .
Nov 21, 2015 | Hard Computers & Internet
Hi I got bluescreen when am install window xp
There would usually be information on the blue screen to help us diagnose the problem but there is more comment that needs to be made. If you still have just the 128M of ram and the 10G hard drive then forget installing xp. xp needs a minimum of 1G ram to work in and that is the maximum your machine can hold. Secondly, the 10G hard drive will only just work when you have got SP2 & 3 installed - there will be no room left for anything else.
Additionally, this machine will be quite slow with a P3 processor running at 733M but it's your choice.
If you want to install xp on this machine I would suggest getting the ram to maximum and a larger hard drive installed before continuing. If you have already done this then please get back to us with any error message that may be on the blue screen.
Apr 17, 2011 | Dell OPTIPLEX GX 110/200 PIII-733MHz 128MB...
My Dell PC scan says that my Samsung SP2504C hard drive is about to fail and should be replaced. Is this something I can do?
Replacing the hard drive involves the following process:
  1. Turn off and unplug the computer
  2. Remove the two screws from the left panel (facing the front of the tower)
  3. Slide the left panel back and to the left to remove it
  4. Unplug both power and data from the hard drive
  5. Unscrew the hard drive (You may need also remove the right panel to get to additional screws)
  6. Slide hard drive out
  7. Slide in new hard drive.
  8. Screw in new hard drive in approximately the same fashion as previous hard drive was screwed in
  9. Plug in power and data
  10. Re-install panel
  11. Plug computer in and boot
However, if this is your main or only hard drive, you will need to install your Operating system and all of your software and files from scratch. It may be possible to preserve them, but that's often risky and requires a bit more work. If this is your main hard drive, you probably want to consult an expert on having the old drive contents moved to the new drive.
If you like my solution, please vote for me,
Apr 09, 2011 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
I installed oracle 10g express edition.now I dono how to remove it. please let me kno how to uninstall it.I even stopped the oracle services but i dino abythin further.
Follow these steps:
  1. Open the Windows Services utility: From the Start menu, select All Programs, then Administrative Tools, and then Services.
  2. If any of the following Oracle services exist and have the status Started, then select each of the services, and click Stop:
    • OracleXE
    • OracleXETNSListener
    • OracleJobSchedulerXE
    • OracleXEClrAgent
    • OracleMTSRecoveryService
  3. Exit Services.
See also the Microsoft online help for more information on stopping services.
7.2.2 Step 2: Remove the Oracle Database XE Registry Editor Settings Follow these steps:
  1. Log on to Windows with Windows administrative privileges.
  2. Ensure that you followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop the Oracle Database XE services.
  3. Start the Registry Editor at a command prompt:
    SYSTEM_DRIVE:\> regedit
  4. Go to HKEY_CLASSES_ROOT.
  5. Delete the following keys:
    • NEED TO CONFIRM THE XE-SPECIFIC ONES.
  6. Go to HKEY_CURRENT_USER\Software.
  7. Under Microsoft\Windows\CurrentVersion\Explorer\MenuOrder\Start Menu\Programs, delete the Oracle Database 10g Express Edition key.
  8. Go to HKEY_LOCAL_MACHINE\SOFTWARE and search for the ORACLE group key.
  9. Expand the ORACLE group key and then delete the KEY_XE and OracleMTSRecoveryService keys.
  10. Go to HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBCINST.INI.
  11. Expand the ODBCINST.INI key and remove the Oracle in XE key.
  12. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services.
  13. Delete the following keys:
    • OracleServiceXE
    • OracleXEClrAgent
  14. Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Eventlog\Application.
  15. Delete the Oracle.xe key.
  16. Exit the Registry Editor.
  17. Restart your computer.
7.2.3 Step 3: Update the System Variable Path Follow these steps:
  1. Open System from the Control Panel.
  2. In the System Properties dialog box, click the Advanced tab, then click the Environment Variables button.
  3. Select the system variable Path and edit the Path variable to remove the Oracle Database XE entry. For example:
    C:\oraclexe\app\oracle\product\10.2.0\server\bin;
  4. Save your changes and then exit the Control Panel.
7.2.4 Step 4: Remove Oracle Database XE from the Start Menu and Desktop Follow these steps:
  1. Select Start, then All Programs, and then Oracle Database 10g Express Edtion.
  2. Right-click Oracle Database 10g Express Edtion and from the menu, select Delete.
  3. On the desktop, right-click the Get Started with Oracle Database 10g Express Edition icon and from the menu, select Cut.
7.2.5 Step 5: Remove the Oracle Database XE Directories Follow these steps:
  1. Ensure that you have followed the instructions under "Step 1: Stop the Oracle Database XE Services" to stop all Oracle Database XE services.
  2. From the Windows Explorer, navigate to the directory where you installed Oracle Database XE, for example, c:\oraclexe.
  3. Right-click the Oracle Database XE installation directory and from the menu, select Delete.
7.2.6 Step 6: Install and Run the Windows Installer CleanUp Utility Run the Windows Installer CleanUp utility to remove the Windows Installation configuration information for the Oracle Database XE installation. You can download it from Microsoft at:
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
he deinstallation completes, click Finish.
Sep 14, 2010 | Oracle Database 10g
My computer cant find my external hard drive
Sounds like the drive isn't working, but the next step is to try it on another computer. If it doesn't show up there either, then the drive is faulty.
May 31, 2010 | Maxtor OneTouch II external hard drive...
Uninstalling oracle 10g from vista
To uninstall oracle from your PC,
first you should run the oracle setup from the installation disk.
The installation setup will automatically detect the oracle products installed in your PC.
After checking the list of installed products, mark the programs you want to uninstall & then click on uninstall.
Apr 11, 2009 | Oracle Database 10g
Changed HD know laptop wont come on
your hard drive has your operating system on it if you can't boot from your cd you may have to change your settings to do so.you can also back up and change one item at a time for instance put your original hard drive back in long enough to get the new monitor working then after making sure your system is set up to boot from the drive you will be loading your operating system from,change your hard drive again.At least this way you can narrow down what the problem may be.If not fix it.
Mar 16, 2009 | Computers & Internet
Uninstall oracle 10g database
hve uninstalled oracle 10g from xp!! but still one program is left over say oracleserviceXE, that i could not find!! how to remove this, to install the s/w again!! plz kindly help me regarding this
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
