Question about RCA RCM528 Car CD/ MP3 Player
Faceplate Bought a used car has the RCA rcm528 installed don't know how to remove face plate
4 Suggested Answers
  • 41 Answers
SOURCE: Faceplate will not open
Perhaps something is not installed correctly physically. Sometimes if something is a little twisted the way the unit is installed it will keep it from opening properly. Try moving the unit slightly and see if that helps.
Posted on Mar 16, 2008
SOURCE: face plate
the face plate is not removable it only folds down
Posted on Apr 15, 2008
brianw74
  • 400 Answers
SOURCE: I bought a RCA remote and i don`t know how to used
Google the name and model of the remote and put instructions behind it....If you don't know the model, it may be under the battery lid (either inside or on the lid itself). If its not there, you can go to google images and type in rca universal remote and find one that looks like yours and it will tell you the model. I have done it before.....
Posted on Mar 14, 2012
How do I get my faceplate to work?buttons on faceplate don't work.
First thing is to make sure the cause. Do you have clock or any display? Is it a new installation? If so, check wiring. If failed, then the face plate itself could be bad. Call customer relations. the phone number is in the user manual.
Mar 07, 2012 | JVC Car Audio & Video
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
How to take the faceplate off of the kdhdr30
The farthest righ bottom button should be the one to push and the faceplate should eject on one side so you can remove it carefully.
Nov 22, 2008 | JVC KD-PDR30 CD Player
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
Daewoo Cd player
The car security is not connected to a head unit. It probably has a small blinking red light on it which blinks when you remove the faceplate and switch the ignition off. This is just an indicator which lets people see that the face plate is removed.
You can replace the headunit with any brand/model you want. It would be cheaper than buying a replacement faceplate.
Aug 03, 2008 | JVC KD-S5050 CD Player
Stereo issues
I'm assuming that you installed the head-unit new and that the faceplate did (at one time) previously slide down the way it was intended to work - is this assumption correct?
Is the molding around the head faceplate (mounting ring) damaged?
Are you sure you're not using the semi-permanent mounting configuration??
(see page 6 of the manual)
This particular unit has the option for a semi-permanent mounting of the face plate. If the two screws are inserted into the sides, it will lock the face plate in to the head unit (have you done that?) - if so, removing the screws will allow the face plate to be removed.
May 29, 2008 | Dual Electronics BDS692 Coaxial Car...
Aiwa fm/am compact disc player cdc-x304 face plate
Buy a new radio, you'll never find just the faceplate... trust me on this one it's not worth the headache.
Mar 30, 2008 | Aiwa CDC-X304 CD Player
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
How to remove face plate
All i did was slip a knife blade between the silver part and where the face plate meets it. It simply pops out after aplying some upward pressure. There are a few places where the face plate has to be popped before the entire thing is free
Oct 12, 2007 | Motorola Cell Phones
RCA RCM528 Car CD/ MP3 Player Logo
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeff Turcotte
Jeff Turcotte
L Pfaff
L Pfaff
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
