Df-3035 copier i have an error message f-61 on my copier, what can i do to fix this problem?
  • 287 Answers
Hello flyersgirl68,
I truly wish I could help you. But , you would not believe how helpful it would be if I knew what brand copier you have. Canon makes a 3035 copier but they have no error codes that start with f. Mita "MADE" a copier (1986) that had an "f" in their error codes that indicated the feeder had a problem. I guess we might want to narrow it down a tad. Is your machine a ...........canon,olivetti,mita,ricoh,savin,oce,kodak,xerox,minolta,konica,nashua,pitney bose,danka,savin,gestetner,monroe,ibm,imagistic,panasonic,toshiba,lanier,brother,riso,......etc....
Posted on Apr 27, 2008
Error code e000225-0001 for canon I r 3035 what I do pls. help me
The light intensity of the CIS is faulty.
During DF stream reading, the sheet-to-sheet light intensity is faulty.
Disconnect and then connect the flexible cable. Replace the following as necessary: flexible cable, CIS, reader controller PCB. Canon iR3035 Error Codes List page 3 from 16
Aug 15, 2016 | Canon iR3035 Copier
When i switch on it say switch off then switch on again but it repeat the same message eventually display error E000007-0000.what is that problem?
Check The Fixing Unit Film.
  1. Replace Fuser Film.
  2. The White mark of Fuser Film must be place in write side.
  3. The White mark reader sensor must be free from dust and Toner.
  4. Use fuser oil and white grease for fixing unit.
May 30, 2016 | Canon imageRUNNER 3035 Black and White...
How to fix system error c6050 on my km-3035
It is a fixing assembly error code. The thermistor doesn't detect heat. Kyocera you replace the fixing assembly. You may be able to reset.1087 1087 gets u into served mode go to reset and activate.power off and on.
Feb 02, 2015 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
50.6 fuser error on hp lj 3035 mfp
Unfortunatly you have to change the fuser , the 3035 need a techinical , it's not easy to fix . cod. RM1-3045-020CN
Sep 26, 2014 | Office Equipment & Supplies
My canon machine is IR 3035 and having a error code E000001-002 How can I fix this.
this is error code for abnormal temperature rise in fixing section.
You can try to reset error in service mode, but if the problem persist you need to change the fixing film unit.
To reset the error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose: COPIER>FUNCTION>CLEAR>ERR.
Turn off and back on.
Hope that helps!
Aug 22, 2011 | Canon imageRUNNER 3035 Black and White...
I have a canon copier ir 3035, its giving error code E000002-0000, whars the problem?
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
Aug 21, 2010 | Office Equipment & Supplies
Message d'erreur sur la Kyocera
Make sure document feeder cable screws are tight and if cable guard (metal bracket) is not installed make sure it is not too close to the wall.
Mar 27, 2008 | Kyocera CS-2550 Black and White Copier
Brother MFC 420CN error message DF
Did you had lightning strikes or a high tension the days before? DF means that the faxmodem which is placed on the pcb is in disorder. The pcb has to be changed (sparepart is more expensive then a new mfc!)
Oct 03, 2007 | Brother MFC 420CN All-In-One InkJet...
ERROR ON iR1018J CANON COPIER
good morning i have one problem whit my copier machine IR 1018j
the copier display error system 247 .
anyone can help me?
Sep 18, 2007 | Office Equipment & Supplies
138 people viewed this question
k24674
