Question about Brother MFC 8440 All-In-One Laser Printer
My machine said it needed to replace the drum. i did. it still shows it and it wont copy any paper?
  • 103 Answers
Replacing the drum takes A little expertise for this machine.make sure the drum specification meets your machines specification.
remove the durm and wait for a day or two carefully fix drum and make sure it is properly sitted in position (coppier shold be off all this while)
Start machine And allow it to come on fully before use. if problem persist make sure invite an experct
Posted on Jul 06, 2010
Smudges on paper and ink is light when it does copy correctly.
It sounds like your drum unit needs to be replaced. Do the smudges look characteristically like a finger print? Technicians have a rule of thumb. Replace your drum, developer compound and general service the machine as often as you service your car. Assuming you do service your car as often as I do, it should be after every 25,000 copies. If the machine has never been serviced then its time you did.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Streaking or banding on the papaer
*** NOTE*** does machine have an ADF (auto document feeder)? Are you feeding the paper through the ADF to make copy? IF machine has ADF and you get the lines from that, place original on the glass and make copy. Does the copy have the lines? If so continue. If not lines then clean the '**** glass' ( thin small glass that the original is pulled over in the copy/scan process. This is under the ADF.
Next, if problem not rectived, it depends on how the paper is fed ( comes out of the machine). Let us say that the paper cover out of the machine 'letter' or ' portrait' and you look at the copy --- the lines are from left to right on the copy, okay. These lines could be from the fuser ( the hot area), pull the fuser out and look at the fuser rollers. Do the fuser rollers have lines -- if so then the rollers need to be replaced. If not then you are looking at the drum / transfer unit. Probably a blade is bad and will need replaced. To tell whether it is drum or transfer -- start to make a copy and open the front cover as to stop the paper in mid-stream. This way you can tell which unit has the problem.
NOW -- lets us say that the paper is coming out 'letter' again but the lines are from Top to Bottom. You will also want to look at the drum and/ or transfer units. This would but a 'stall' or 'blade skip' problem. Again, start to make a copy and open cover in mid-stream to see which unit has the problem.
If the drum unit is the problem, replace blade and maybe drum. IF the transfer unit is bad, replace transfer blade, roller and maybe the transfer belt ( if belt is present). Some transfer units use belts and other rollers.
Jan 24, 2009 | Office Equipment & Supplies
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
Problem on Toshiba e-studio45
2 possibilities -
drum or drum blade going bad
Open machine and look inside the drum is the shiny cylinder( do not touch) do you see a black ring around it? replace drum blade if yes.
Jul 13, 2008 | Office Equipment & Supplies
Vertical lines on copies received
Run a copy of something through your machine. IF the lines show up on your copy, and also lines on your incoming faxes, then your drum cartridge is bad.
Replace the drum cartridge with a new one and you should be back in business.
If you have any other questions, please post again.
I hope I have helped you with your question.
Please remember to post a rating if I have helped you.
Have a good day.
Mac =)
Jun 04, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Copier
Take a look at the paper path. You should see a glass strip somewhere. This is that "sees" the paper. This glass is probably dirty. Take a soft cloth moistened with rubbing alcohol or maybe Windex and clean it. Even a small dot on this glass will show as a long line on your paper. If the line is still there, it may be on your drum which will need replacement.
Hope that helps.
May 07, 2008 | Brother IntelliFAX 2600 Fax
Cannon Copier
Sounds like your drum cartridge might be bad.
Something you can try that might narrow down the problem is to make a copy of something and shut the copier OFF in mid copy.
(Basically, when the light is about 1/2 way finished scanning.)
Then, open the machine up and removed the jammed paper which should be 1/2 way through your machine and hopefully about 1/2 way under the drum/toner cartridge unit.
See how the copy looks at that point. **** FYI **** The toner on the paper is NOT FUSED so it will RUB OFF. Keep the paper away from your clothes and toss it.
IF your copy has smudges on it, then there is a real good chance that your drum unit is bad and needs to replaced.
If the copy looks good, then there is a possibility that the fuser unit is bad and needs to be repaired.
I would say that your drum unit is bad with my experience with Canon Copier.
If you still have more questions, feel free to ask.
Have a good day.
Good luck.
Mac
Mar 23, 2008 | Canon PC-D320 Copier
PC-65 (Canon copier)
A smudge across the copy can be in many different areas.
Some ideas.
The drum cleaner may be the problem as you indicate.
It may be a piece of paper ripped of dragging across the surface of the paper causing the smudge.
Also the fuser roll coating may be very worn and causing that.
One thing to try that can show you if the defect is on the drum cartridge, is start to run a copy, After the paper feeds and this is timing, shut the machine off when you think the paper should be about half way through the copy cycle, then see if the copy defect is on the unfused page, If it is smeared before it reaches the fuser, it is in the cleaning section, if it is not smudged, then it is most likely the fuser rollers are needing replaced.
First look for a paper fragment in the path, step 2 is to shut the machine down in mid copy and see if the defect is there.
The fuser is the hot area of the machine in the exit area, If you can take a flash light and look in there and see if you observe wear or heavy toner buildup on a roller then obviously thats the problem.
Jan 02, 2008 | Canon C130F Black and White Copier
Brother MFC 8440 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
