Question about Car Audio & Video
I have spl crm520-2 amp and the light does not go on
I have spl crm520-2 amp and the light does not come on but when i disconnect the ground the light goes red
  • 24 Answers
Power supply is bad spl is not a good compane i would replace the amp
Posted on Jul 08, 2010
I Have an spl audio amp 520 watt and when it turns on it automatically goes to red which is protect. what could be causing this problem
It could be 3 things. There could be a short somewhere, your ground isn't strong enough, or you accidently switched up the ground line and the power line on the amp. Since the fuses aren't blown I would say that your ground isn't strong enough.
May 01, 2011 | SPL Car Audio & Video
Amp goes straight to protecting
bad power supply or out put i hat to say it but spl is note a good company i would replace the amp
Jul 07, 2010 | SPL Dynamics CRM1200-2 Car Audio Amplifier
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
When i turn the amp on the light turn red and it goes off no green light g the amp was getting hot shotting down
when you hooked the amp up did you make sure your speakers were all in-phase positive to postive / etc.. a common issue with hi-power equiptment is grounding whatever input power supply gauge wire was used the ground has to be equalized, also if youre drawing too much on the amp (too much speaker/not enough amp ) this problem will continue till the amp cooks, check all phase, and if youre mono-bridging make sure this amp can be mono-bridgeable that would also send an amp into protection mode because its recognized as a short to positive-good luck
Jan 17, 2010 | SPL Audio Phantom DK2-1000 Car Amp
!!!red protect light is on!!!
Hello beaugarcia26,
Unless the amp itself is defective, there's a short or ground somewhere.
First disconnect the speaker wires and RCA (or high level) inputs, leaving just ground, remote turn-on and power leads connected. Then see if the amp powers up normally. If it doesn't check the ground with a multimeter and make sure it is good. If the amp powers up normally, check the speaker, speaker wires and inputs for shorts or grounds.
Hope this helps.
Sep 02, 2009 | Hifonics Brutus BX 1205D Car Audio...
Power protec is signal red on
Missmatched impedence, ie you are running your amp which is 4ohm load to a sub which is 2ohm load, insufficient grounding could be the cause, blown transistor within the amp possibly.
Jul 30, 2009 | SPL Dynamics XL2-820 SPL Car Audio...
The fuse blew on my spl 1920watt amp and now the protect light wont go off and it wont do anything
Did you put a new fuse in it? If you didn't then put a new fuse that is rated at what the amp calls for. If you have and the light stays on, then odds are there is a broken wire inside and the amp needs repairing or replacing.
Jul 12, 2009 | SPL Audio Car Audio & Video
Car Audio & Video Logo
71 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
