I have a mitsubishi ws-55511. Light just blinks. I replaced the 7 caps that is recommended but problem still exists. DM board possibly?
  • 6,993 Answers
mostly likely, the fault should be from the DM board. But its really very hard to guess a TV part without actually testing the board to know the exactly fault. You can consult the service manual for this TV. It will direct you to the fault of the TV and a way of fixing the fault.
You can find the service manual for your TV on the below link. make sure you read every information on the manual thoroughly, to get to the root of the problem. Also, you might print it out if possible. This will really help a lot in solving the problem.
http://www.scribd.com/doc/6677240/Mitsubishi-Service-Manual-Chassis-V21
Allow the link load completely because it will actually take some time to load on the pages fully, because they are many.
I wish you good luck.
Posted on Jul 06, 2010
  • 484 Answers
The reason your laptops light keeps blinking and there is no display on the screen is because there is a problem on the board of the television.
There is power getting to the television, but the board is not receiving it to start working, that is why it is blinking.
First try to secure its connection to a power source is tight and not loose, then turn it on to see what happens.
If it does the same. all you have to do is to change the main board of the television. After doing this your television will be in good condition again.
Take care
Blinking green light
Replace the 7 capacitors on the DM board. That should solve the Issue. You can get the Mitsubishi WS48511 - WS65511 DM repair kit from www.tvrepairworld.com which has the upgraded replacement capacitors and the CD with repair instructions.
Jun 19, 2012 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 green light changed caps. where is pico fuse located ?
There are at least two pico fuses in the DM unit along with the caps; DM is large metal box on left as you look from behind.
Blinking green light that does not stop means problem is in DM unit that is not booting up.
If you have questions let me know.
SD TECH
Sep 29, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Need to know where capacitors are on mitsubishi ws 55511 tv are located at have back of tv off and cant locate them please help thanx
they are located inside the DM modules case( Metal Case on far left side ) open the metal case and you will see 7 caps on the DM power board. I am posting a pic of the board with the 7 caps that need replacement use 1000UF 25V caps to replace the 1000UF 16V caps that are currently installed.
Aug 08, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power wet off and now the timer green light is flashing and it wont turn on model # ws 55511
Thats caused by the 7 capacitors on the DM power board. They discharge when the power is lost and then cannot recharge when power is restored and the indicator light will blink non stop indicating the DM has not completed the boot sequence. Replace the DM caps. The WS48511 - WS65511 DM repair kit is the correct repair kit for your model. You can get the repair kit from www.tvrepairworld.com
Jul 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Ws-55511 replaced all 7 caps in the dm, still wont power on
I have seen this only 2 times----you may be able to unsolder and remove the reset micro switch---you have to remove the whole screen to get at it---the micro switch board may not be available---the switches can be tested with a ohmmeter set to high end and of course should not have a reading across them--I bet the reset switch is bad--you can remove it and put the keyboard back---most of the Mitsubishi sets use the same type of switches--Only other thing is leave the keyboard disconnected and just use the remote.
Glad you found the problem.
Regards, SD TECH
Sep 14, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 DM 5volts draged down blinking led
Did you check the caps on the DM board? They usually go bad after a period of time. Remove the DM board and the metallic cover and there should be 4 to 7 capacitors (There are different revisions of the DM board). Check these caps also, replace if needed.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Apr 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi rear projection tv won't turn on
know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 08, 2008 | Mitsubishi WS-55511 55" Rear Projection...
TV wont turn on
replace DM
Picture of bad caps
Oct 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Help my ws-55511 can anyone help me with this.
Changing caps on DM board is good prevent maintenance,
 but does not represent the solution...DM caps symptom is
 Continuos blinking light.
 See    " problem 351"    On 10/20   WS 55908  comments.
  Let me know....T.
May 16, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
