Question about Amcor AF9000E Portable Air Conditioner
Where can I get a replacement adjustable window slide bar
3 Suggested Answers
kebah
  • 683 Answers
SOURCE: where can i buy or
Try visiting htp://www.amcorgroup.com/english/manuals/PCMA.pdf
It is a pdf file (owner's manual).
On page 15, there is a list of amcor group offices on different region which could help you in locating the nearest authorized parts dealer in your area.
Posted on Jun 07, 2011
heatman101
  • 43501 Answers
SOURCE: The adjustable window slide bar is too big for our
Yes, but if possible pull the slide all the way out and then cut from the inside of the slide so the outside is not altered..
heatman101
Posted on Jul 05, 2011
My screen icons are to large to work with. How do I reduce there size in Windows 10.
From the desktop
  • Press Win Key + i
  • Click on System > Display
  • Adjust the slide bar to the left to adjust the size
If its all the way to the left then you may need to click on Advanced Display settings and adjust your screen resolution.
Sep 29, 2015 | Computers & Internet
How do I get the chain back on
Remove the two nuts on the side of saw. Then remove cover and slide the bar backwards to create slack in chain. make sure the tension adjustment nut (usually square head) is in groove of bar. When chain is back on bar slide the bar forward taking up the slack. Put the cover back on, put the nuts back on and with a slotted screw driver turn the bar adjustment to take up the slack. The chain should lift off the bar slightly but not so much that it is loose.
Sep 22, 2015 | Garden
How to replace chain adjuster
Hi Jack:
Sounds interesting. I've owned a bunch of chain saws and never had to replace the chain adjuster. That said, it should be quite straightforward.
Start by removing the bar and chain.
It NEVER hurts to clean things at this point.
Depending on the saw, there are a few different devices, but the principal is the same..... turn screw, holder provides "anchor" point, adjuster moves along screw....pointy bit fits in slot in bar to make bar move.
Once you can see it, you should be able to slide it out, or unscrew it until it is free.
Take your time, be patient, and have fun.
Keep track of the various plates that sandwich the bar so you know how to put it back together.
Cheerfuls!
Jun 13, 2015 | Garden
Adjust screen brightness
Yopu can adjust the brightness of the monitor from the avaialbe panel buttons Alternatively you can do so from the Operating Sytem brightness control which depends on the platform you are using. If its windows you can navigate to control panel and the power settings and adjust the brightness by sliding the slide bar as desired.
Sep 21, 2013 | Hyundai ImageQuest Q17 17" LCD Monitor
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
My computer's screen resolution is too low
Hello to adjust your screen resolution, right click on the desktop and either click properties for Windows XP or screen resolution for Windows Vista/7. Then for XP click settings and you will see a slider bar where you can adjust your screen resolution. For windows 7, it will be on the screen that opens up, just slide the bar into the resolution you want.
Thanks for using FixYa!
Aug 15, 2011 | Computers & Internet
I have a Sony vaio laptop with OS of windows 7 Home premium and converted to window 7 ultimate. My problem now the screen is dim and I can't adjust the brightness
1. Click on Start -> Type " Personalization " / Right Click on the desktop Left Click on " Personalize " 2. Under the Personalization window Click on Windows Color 3. Slide the Color Intensity bar to the right ....
Hope This Helps
May 29, 2011 | Sony Computers & Internet
Re-install chain
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Look carefully at the picture and your chain, it can be mounted backward; they do not cut when backward.
Dec 04, 2009 | McCulloch Garden
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Amcor AF9000E Portable Air Conditioner Logo
60 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
