Question about Maytag Neptune MAH5500B Front Load Washer
MAH5500B Neptune front loader- washer may only run just enough water to put detergent in the cycle, after that it does nothing at all. It keeps pausing on its on. In order to get the water out I have to put in on spin, to get the water out. It's taking a long time to respond to the seletions I make to even start washing any clotheing. The washer will be counting down, then pause, but I don't even hear anything happening at all. It was just working fine one day and now its not.
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link bellow to diagnose your problem and the resolution to it for your washer….
http://www.repairclinic.com/Washing-Machine-Troubleshooting#Itdoesntworkatall
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 06, 2010
My Neptune is shutting down with a SUDS error
Check your drain hose for kinks or blockages, check filter and pump for blockages, check wire harness connections to pump, pressure switch and CCU.
If machine will start- If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Dec 29, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer keeps leaving bleach speckles on my clothes. How can I fix this?
Possible that the rinse cycle is not adequate and so does not wash off the detergent that is dozed upon. Check the water level or sett it a little higher. Make sure the belt is tight and fitting and the motor RPM is correct. Choose another program to confirm
Jul 05, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have a neptune front loader, after the wash cycle is complete the clothes smell like they have not even been wash with a **** moldy smell. I use Tide HE as directed but they still smell like i...
Hello, Thank You for using FixYa. I will be helping you today.Try 2 cups of white vinegar on a heavy duty cycle with hot water.Pour it in the detergent dispenser after it starts to fill. Also the affresh tablets work good i would use 3 tablets at one time if your unit is as bad as you say.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front loading Maytag Neptune doesnt drain all water
the washer has a low level of water in it at all times. it will never completely drain out unless you pump it. this is one of the reasons there is such a smell with these washers, i use vinegar in rinse cycle and i use bleach once sometimes twice a month to keep mold and mildew smell away.
Mar 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Where do I put detergent?
As you face the front of the washer on the left the first receptacle is for the softener, the second for the bleach and behind that is an open area ("pit") where the detergent should be dposited to be perfused by water at the beginning of the wash cycle.
I had to label these areas since the lid normally covering this area was the first thing to break on this washing mashine.
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG Mah4000 front loader washer
HAVE YOU CHECKED THE MOTOR CONTROL BOARD?IT IS LOCATED INSIDE THE FRONT RIGHT BOTTOM OF WASHER BEHIND FRONT PANEL,LET ME KNOW IF YOU FIND ANYTHING-MIKE
Nov 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
