Question about Yamaha HTR-5830 Receiver
Connections diagram? I can't connect the receiver to my cable. I'm usually pretty goodmat this stuff.
  • 677 Answers
Hello, you can use this link to know how to connect Any device toyour receiver .
askville.amazon.com/connect-cable-dvd-receiver-vcr/AnswerViewer.do?requestId=360702.
Hope it helps.
Posted on Jul 06, 2010
How do i change the positive battery terminal cable only because it is slightly melted and car won't start?
It is important that battery connections are good and tight. If your cable is damaged, it is best to get a new one along with the terminal connections and is not expensive. It's pretty easy to see how the connections are made, but if you're unsure, just consult a parts store rep. They're usually pretty happy to lend assistance. Replacement time is probably about 10 minutes. Be sure the battery is completely disconnected before replacing any cables.
Jan 24, 2015 | 2000 Ford Focus
Hdmi plug
What kind of connections do you have? There are many adapters available to convert one cable format to another (ie dvi to hdmi) You can find pretty much any converter at endlesscables.com
Dec 25, 2011 | Arris DCT6200 DTV Receiver
HOW DO YOU CONNECT CABLE BOX
Connect a Cable Box to a Receiver:
1 Gather all your tools, parts and cables together before you start the connection process. Chances are you will need to connect several items at the same time, including your TV, audio system and TV cable receiver. Your cable box manual is likely to include a diagram of how to make the appropriate connections, so it's important that you read it before attempting any links.
2 Connect the output of the cable box to the input of the receiver. If you are connecting an audio system as well, make sure the audio output cables go directly into the receiver and, from there, to the cable box. Avoid direct connections; instead, go through the receiver for all secondary connections.
3 Select the correct jacks for sound and video. A newer model of receiver should offer several options, including analog TV out and DTV out. It should also offer an S-video and a service port. Depending on the type of cable box you use, one or more of the same jacks will be available there, too. When connecting both systems, make sure cables go between similar outputs.
4 Use an S-video connection cable to link your TV with your cable box. S-video connection cables allow you to preserve good quality in both image and audio. Most cable boxes come with S-video connection cables, but you can get them at any electronics store. Once you have them, simply connect both ends to the right output. It'll be easy to identify, because it's usually the only round one available.
5 Plug the TV, cable box and receiver into an electrical outlet to make sure everything is working properly. If you are getting static or interference, you may need to tighten the connections or change the cables.
Sep 03, 2011 | Sony KV-35V65 TV
No display no music nothing
have you checked the mini fuse that is on the back of the radio itself?
Mar 07, 2011 | Pioneer DEH-P7800MP
Connecting cable to receiver
Do you mean 5 RCA audio outputs marked as FrontLeft, FrontRight, RearLeft, RearRight, Center? Unfortunately this receiver doesn't have discrete 5ch inputs (as yamaha calls it on its webpage).
But the cable box should have also digital audio SPDIF output - that is either optical (square connector) or coax (RCA usually orange). You can use this for connecting to receiver.
Mar 07, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have lost my digital satellite reception. All I getting is No Signal or Bad channel.
could be a couple things. First I would check the cable(s) from the dish to the box. Check whether the connections are corroded, but also check the insulation. squirrels, rats mice and birds love to eat the stuff. You have a signal leak somewhere. If everything looks good there, you might check the positioning of the dish itself. maybe it moved during a storm.
Aug 29, 2009 | Coship CDVB2000E
Moniter Data Cable Pin Connections
Download the user's manual. Usually such information is given there.
Jul 17, 2009 | Zerus Intel Desktop Board D815EEA...
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
How to connect to digital cable box and TIVO
Click here and start at page 24 to see a diagram on how it should be hooked up.
Sep 23, 2007 | LG 42PC3D 42 in. Plasma Television
Yamaha HTR-5830 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
