Question about HP Officejet 4315 All-in-One Printer
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really slowly.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 53 Answers
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
***** IF THE PRINT SPEED IS MORE THAN 60 SEC.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
CHECK THE CARTRIDGE COMPATIBILTY.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) http://www.hp.com/buy/suresupply and check The number on the cartridge label must match the numbers listed on HP SureSupply.
PERFORM A RESET.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
Posted on Jul 06, 2010
Wont print received attachments
You should download the attachments before giving the print command. This will fix your problem. Good luck. Thanks for using FixYa.
May 31, 2010 | HP Officejet 4315 All-in-One Printer
My hp officejet printer 4315 wont print
Good day Sir, the onscreen help provides troubleshooting topics to assist you in resolving any issues you might encounter with the HP All-in-One. In the HP Solution Center, click tab for Hp all in one. In the device support area, click onscreen guide or troubleshooting.
have a nice day. hope this will help you.
May 19, 2010 | HP Officejet 4315 All-in-One Printer
When I try and scan the Office 4315 says "No scan options" How do I fix this?
go ahead an put the cd in then go to my computer>>right click on optical drive>>explore>>utill>>ccc>>uninstall l2..remember while doing this usb cable must be unplugged...restart the computer...try to install the printer...when ever it will ask u to plug the USB cable..do that...best of luck
Apr 01, 2010 | HP OfficeJet 4315 All-In-One InkJet...
My hp officejet 4315 all-in-one printer is showing a cartridge error message I have changed both cartridges and still reads the same what is going on with my printer.?
Please reset your Printer and restart again . The go printer properties and start the printer diagnosis & start test print. If that function going well then your printer ready for further printing with out showing that massage.
Thanks.
Feb 02, 2010 | HP OfficeJet 4315 All-In-One InkJet...
My hp officejet 4315 only prints in black
Good day, To print from software application (windows) follow the procedure below.(for hp officejet 4315).
1. Make sure you have paper im the input tray.
2. On the File menu in your software application. click Print.
3. Make sure the HP officejet 2315 all in one is the selected printer.
4. If you need to change settings. click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, of Preferences.
5. select the appropriate options for your print job by using the features available in the Advanced, Paper/Quality, Effects, Finishing, and COLOR tabs.
6. Click OK to close the Properties dialog box.
7. Click Print or OK to begin printing.
God Bless.
Oct 19, 2009 | HP Officejet 4315 All-in-One Printer
HP Officejet 4315 All-in-One went offline
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 31, 2009 | HP Officejet 4315 All-in-One Printer
I have 4315xi Officejet All-in-One printer. We have used it as a
Make sure all software is installed on computer. On the face of the 4315 is a button for "Answer Mode." This is an option to tell the printer what to expect and what to execute when a signal or call comes in. If it in "Fax Answer Mode" it will answer on how ever many rings you tell it to.
Nov 20, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Hp officejet 4315 how to switch from fax mode to print
There is no "print mode", Fax, Copy and Scan are modes one can enter, printing on the other hand is done when a print job is detected from your computer
DRIVERS to suit download link
Download Manual and Setup guide HERE
Please rate solution as fixed.
Nov 19, 2007 | HP Officejet 4315 All-in-One Printer
663 people viewed this question
Seeker5211
Seeker5211
