Question about OKI C9600hdn Led Printer
My prints come out with a yellow tint. I've replaced the drums for each color. While that may have made the prints look a little better everthing still looks a little yellow. Printer: OKI C9600
  • 1,219 Answers
Check/ replace transfer unit.
Posted on Jul 07, 2010
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
I have Canon C3220 and after 200 color copies or so i get a yellow tint on the whole page that i am printing. It gets darker the more i run. It seems like it does it more the warmer the machine gets. ...
Hello stunt,
I have been working on Canon copiers for 23 years. Which means nothing. But if I were you I would replace the yellow drum unit. It's easy and not that expensive. I have no way of knowing how much "color" output you use but even if you use very little color, at some point the color drums break down due to shear time. Remember seeing "AUTO GRADATION" once in a while? The device is calibrating ALL colors during this function. That means cyan, magenta and YELLOW drum and dev units are being churned as well as black(k). Now, considering all that,it's merely a matter of time till you will see a caste of blue (cyan) or red (magenta) as they all wear at about the same rate. My point is, you could replace just yellow or you should replace the other colors as well. You must make the decision based on your needs. Cost versus pre-emptive care. i know it's a cheesy analogy but if you have a car and the tires are quite worn, and one finally gets SO worn that it goes flat..............etc....etc.... . The drums are simple to replace and the copier will recognize the new drums and will take care of itself. All you need to do is remove the old, put in the new. Drop open the front cover. You are now viewing the front of the internals, the same way you have in the past when you've replaced toner. You will see 2 handles. The lower handle swings down and allows you to remove the waste toner bottle( among other things). The upper handle gives you access to the drum units. Turn it counterclock wise and lower the door that you have now released. Now you see the drum units located directly below the toner units you have replaced in the past. There is a hand grip on the front of each drum. Just grasp the front of the drum you wish to replace and slide it straight out. The replacement (new) drum will be labeled with its color. Don't worry you can't put the wrong drum into the wrong spot. Unbox the drum, remove all the orange tapes and ****. When you are done you will see NO orange(yes remove the pull pins located at each end). But you "will " have a gray cradle that remains on the bottom of the drum. This used to protect the drum as you slide it in. The gray cradle has "locators" that help you align the drum for proper insertion.Once you have "located" and aligned the proper insertion spot and angle, push the drum unit in. The gray cradle will remain behind as you push the drum in and may be tossed in the trash. Pull the the clear tape straight out. You did it! Yes, whenever you see a tint of a color showing up on your prints/copies and it shows up or gets worse as the run goes along, you are seeing the classic state of a bad drum. The part number is 7625A001AA (black) 7624A001AA(Cyan) 7623A001AA (Magenta) 7622A001AA (Yellow). They are rated at 40,000 prints (approx). I gave a quick look and they appear to cost about 280 dollars (American). Some places more some less. Ok, I hope I helped you. Take care and good luck. :-) SPINAL Please let FIXYA know if I helped.
May 08, 2011 | Canon Office Equipment & Supplies
There is a yellow tint across the majority of the page when I print in color. I have replaced both the yellow drum and the toner cartridge, but the problem is still there...Suggestions?
Hey!!
The only thing i can think of is that the cleaning blade on the Transfer belt is not cleaning correctly!You can stop the page while printing and should see the yellow on the belt!You will need to replace the transfer belt!
Good Luck!!
Jan 07, 2011 | OKI C5500n Printer
Sharp AR-C240P Printer Prints Everything with red cast
iF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Jun 23, 2009 | Sharp AR-C240P Printer
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Streaks in prints
What I would do is remove all cartridges, wipe the belt w/clean cloth use an air can to clean the machine, check the drum on each cartridge see if there is something, it could be there was a change in Voltage and it burnt the drums. change 1 more toner cartridge to see if that color goes away, if it does then you will know if the drums are the problems.
I've had a problem w gen toners doing the exact same thing, so I had to OEM and it went away. Good luck>
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Color print qualities issues
Perhaps you've tried, but check to see if your printer is printing color using the PS driver or the PCL driver. If you are using the PS driver the colors will not print correctly, but this is the best mode to print black and white since it will save your drum life and print faster.
Jan 08, 2009 | HP LaserJet 2840 All-In-One Printer
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
OKI C9600hdn Led Printer Logo
338 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
