Question about Whirlpool ACQ082XK Air Conditioner
Does not cool
Fan runs but no longer cools.
    Sergeant:
    Champion:
  • 230 Answers
First thing to do is check the pipes for leaks. Check the compressor of the A/C unit, it might have been pumping no freon anymore as it might have evaporated into the atmosphere due to tubing leaks. Or the compressor might have gotten bad and having poor compression ratio due to the mechanical properties of the piston-cylinder assembly which has moving parts and prone to wear and tear due to friction. Hope this helps.
Take care
Posted on Jul 06, 2010
  • mbinger Jul 06, 2010
    We will look into this. Thanks!
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Cooling fan won't turn off When car is completely off
Some cars allow the cooling fan to run for up to 10 minutes after the engine is shut down. If it lasts longer have the sensor and relays check out.
Sep 29, 2013 | 2001 Cadillac DeVille
The cooling system electric fans keep running for over 45 minutes. The engine temp gauge was in the normal range. There is no thermostat in the cooling system, the radiator was warm but not overheatin
there has to be thermostat sensor in the system. this is how the cooling fan is controlled.the water pump may be failing by not pumping enough coolant and causing the fan to run.longer that expected
Jun 24, 2012 | 2000 Dodge Caravan
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Ford focus 2006 engine overheating once ac swicth is on..
CHECK TO SEE IF COOLING FAN IS RUNNING.IF NO CHECK COOLING FAN FUSE AND RELAY.THE COOLING FAN NEED TO BE RUNNING WHEN AC ON BECAUSE AIR CONDITIONER PUT A LOAD ON ENGINE.COOLING FAN KEEP RADIATOR AND AC CONDENSOR COOL.FAN NEED TO RUNNING.
Sep 04, 2011 | Ford Focus Cars & Trucks
When it on maybe 1hour or less than that its automatically turn off and it very hot then i leave ten minute and turn on again it okay, and that is the problem with my laptop accer(aspire 5315 series)
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Oct 27, 2010 | Acer Computers & Internet
The fan won't shut off after turning off the car. Takes About 12 minutes it will finally turn off. 2000 VW golf.....2.0 ltr VW replaced the ''module'' but that did not solve the problem. The VW dealership...
That fan is to cool the engine. It is normal for it to continue to cool after the enging is shut off and operates much longer in hot weather than in cold weather. If you think it is cooling to long before shutting off I would check the cooling system to see that it is operating correctly. If no and the engine is overheating somewhat that is why the fan runs longer.
Dec 31, 2009 | 2000 Volkswagen Golf
My laptop computer shut down when run for 5 minutes or so. Do you think is the cooling fan?
It could very well be.
Does it feel hot?
Does it last longer when you boot it up for the first time?
Dec 07, 2009 | Dell (6F858) Cooling Fan
Fan runs after car shut off
You may need to replace your thermostat. This is normal for the fan to run after you turn your car off but if you say its running for 20 minutes or longer, it may mean your thermostat is stuck and causing the fan to run longer to cool off the radiator. Its a good thing for the fan to run. Heat is your enemy. I rather the fan run than no fan at all, if your car overheats, you could blow a gasket or warp your valves and its really pricey if that happens
Nov 25, 2008 | 2002 Pontiac Sunfire
Problem with cooling and fan on frige
no fan then no cooling!
try to localise the problem by removing the fan and powering it up direct from mains. if it works then problem is not with fan
Jun 25, 2008 | Refrigerators
Whirlpool ACQ082XK Air Conditioner Logo
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
