Question about Pantech Matrix Cell Phone
The screen has white bars on it and gets worse under pressure
The screen has white bars on it and gets worse when u press on the screen
    Problem Solver:
  • 12 Answers
Pantechs usually have a 12 month warranty. call em up.
Posted on Jul 07, 2010
The car idle in park for hours,but when drive at high rpm it heats up after a few miles and then smoke come from the exhaust?
Have the coolant checked for hydrocarbons. It sounds like a blown head gasket, but from the cylinder into the water jacket. Under higher pressure the engine heat/exhaust gases will enter into the coolant and pressurize and overheat the system. Then with the additional pressure, water vapor will bleed back into the cylinders and burn off as white smoke. This doesn't seem like a fully blown gasket, but one that has a tiny leak under higher pressure and heat conditions. It will eventually get worse.
Oct 30, 2015 | 2000 Mazda MPV
Have a 95 tb 4,6 it starts fine but then it starts acting like it is only running on 4 cyinders an if i give it trottol it dies
Does it get better if you warm it up? Temp sensor.. Is it worse under load? Plug wires. Ford v6 that year used to eat plug wires...
Fuel to the injector bar doesn't always mean good fuel pump. Check pressure.
Jan 31, 2015 | Cars & Trucks
Canon pixma mx410 document in adf has paper inside
The Alarm light was always on and the screen said "Document in ADF. When I pressed "OK" it would read "Eject the document". ..............................solution, Lift the cover to expose the flat bed scanner glass. Under the cover, there is a long white bar with two white tabs perpendicular to the white bar. One of the tabs was retracted. Pull on the tab until it is fully extended. The alarm turns off and there is no longer the error. Simple solution .....................................THIS WORKS!!!!!!!! thank you
Sep 12, 2012 | Canon Pixma MX410 All-In-One Printer
I have a RENOVA boiler and on the screen it shows F1 problem. What does it mean?? And what I have to do?? Thank you
You simply do not have enough water pressure inside your heating system and therefore the Boiler will not fire up. On your Control Panel, press the Bar/Mode button to display the system pressure... Then under the Boiler you will find a valve (On ours its a Blue knob), turn it anti-clockwise to let in more water, when the indicated pressure reaches that required by your system (On ours its 1.7 Bar) shut the value (Turn knob clockwise) - Then you can restart the system.
Apr 13, 2011 | Heating & Cooling
I have a dell inspiron 15 when I turn it on the dell symbol and insprion page comes up then goes to a black screen. When I press F8 I get black screen with white bars at the top and bottom and a white bar...
You are having a display problem with the LCD, so kindly have it checked from dell and get the LCD display replaced from them if your laptop is under warranty
Nov 18, 2009 | Dell Inspiron 8500 Notebook
Coolant leak/head gasket
If you have a head gasket leaking, and your engine is blowing a white smoke from the exhaust pipe, then you're taking coolant/water into your piston/s.
After a heavy acceleration your pressure is forcing more coolant/water into your cylinders..but don't be fooled..water/coolant is also getting into your cylinder/s when you're driving slow too.
You should get the head gasket repaired as soon as you can, or the head gasket may very well let loose and then you get to deal with having the heads shaved if they warp from the heat.
Either way..you really should get the gasket replaced soon.
Dec 30, 2008 | 1994 Chevrolet Caprice Classic
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
White lines on screen
Contact the maker to ask about repair- but as you have damaged it, its a slim chance. I joke not when I say - drop it again -it may just jerk it back together- any way you can break it worse,
May 14, 2007 | Casio Exilim EX-S500 Digital Camera
TV Bars
These are called vertical retrace lines. They are going to get worse untill you find the bad capacitor(s) or replace the vertical driver/output IC. Please, if you have not the solid state repair experience, get a pro to assist you in this repair as there are no user replaceable parts inside this set. Good Luck PLease do not forget to rate this thread.
Dec 11, 2006 | Curtis CM27002S 27" TV
Pantech Matrix  Cell Phone Logo
76 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
