Question about Plumbing
My Tuscany kitchen faucet drips steadily when turned to the cold water side. It still drips when turned to hot water side but musch slower.
5 Suggested Answers
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 14 Answers
SOURCE: Kitchen Faucet 6310 020 White - HOT WATER SIDE NOT WORKING
The faucet cartridge is more then likely blocked and the faucet will have to be disassembled in order to unblock it.
While it is disassembled you should slowly turn on the water lines to make sure the water ways in the faucet are clear. And thoroughly check the cartridge for damage. Replace if necessary.
Replacement Cartridges can be purchased at most plumbing supply houses or Big Box Stores such as Lowes or the like.
Posted on Dec 27, 2008
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
  • 15 Answers
SOURCE: A new hot water heater was installed in our home.
Did you remove the diverter from the faucet and clean it?
Posted on Feb 24, 2011
How do I replace/repair the sprayer diverter valve in a Tuscany kitchen faucet?
Do you have a model # ? Normally the diverter will be exposed by removing the spout.
Dec 23, 2014 | Plumbing
Hot water will not work in kitchen
leave the cabinet doors open at night . place an electric heater in front of them an leave water turned on a little
Jan 06, 2014 | American Standard Plumbing
Hot water side slower pressure than cold side on one handle kitchen faucet
If problem is isolated to one faucet, then clog is located near that faucet.
I have same problem on one faucet when sediment and dirt collects at shut-off valve for some reason.
Problem can be at shut off or at supply tube or at faucet ... or all 3.
Repairs get things kind of wet so get out bucket and towels.
Take apart center mixing valve on faucet and turn water on to see if problem flushes out.
Disconnect hot side supply tube at faucet. Turn water on and see if that flushes problem out.
Remove shut off valve and turn water on to see if that flushes problem.
Replace shut-off valve.
Next place to look is elbow inside wall.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 19, 2011 | Delta 2402 Classic Single Handle Kitchen...
My kitchen tap keeps dripping all the time how do i stop it
The washers and seals on either the hot or cold side of the faucet need to be replaced. Until they can be replaced and the dripping is keeping you up at night or you don't want to waste water. Turn off the shutoff valves to the faucet under the sink. Just remember to turn them back on when you need to use them.
Feb 03, 2011 | Heating & Cooling
Moen single-handle kitchen faucet only drips on the hot side. Removed cartridge and cleaned out some foreign particles. Replaced and still drips on hot side, not cold side?
have to replace the cartridge..hot water softens rubber and causes it to leak first...check the left side port on valve to make sure no burrs or bites in metal eating away at cartridge seal...
Nov 21, 2010 | Moen & Replacement Cartridge
Water volume has been getting very slow
Could be a blockage in the valves and check any filters any where in line.some sinks in kitchen have a filter under sink and check valve to make sure they are opened all the way.
Apr 29, 2010 | Kohler FortĀ© Single Lever Handle Kitchen...
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
Hot water on cold side when first turned on moen 7600 series
did you replace the faucet cartridge??
if you did, you need to take it out and turn it 180 degree (not head to toe). the water control is on reverse.
Nov 16, 2008 | Moen 7437 Chateau Single Hole Kitchen...
Plumbing Logo
131 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
