Question about Refrigerators
I have a model #ET8CHEXSTO2 refridgeratori'm having trouble with the ice maker not making enough ice. The water flow checks o.k. I've had this problem even in cold weather. Now the maker is very very slow. Any ideas? Thanks Greg Brady
catriver
  • 878 Answers
SOURCE: slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Posted on Mar 21, 2007
catriver
  • 878 Answers
SOURCE: Ice Maker too slow
bayfishr, I'll try to give you an idea on how this thing works and let you do some checks. The cycle is controlled by temp. The harvesting process begins when the IM thermostat closes signaling the harvest temp has been reached. The closed thermostat supplies power to the IM motor and heater. Therefore the colder you keep it, the faster the production unless something has failed. I see a lot of heaters fail. You can test this. When the IM starts it cycle, test the voltage from L to H on the module,they will be marked. Should read 120V. The heater on the bottom of the mold should be getting hot. Disconnect the harnes and ohm it. Should ohm out at approx 72 ohms, same test points. If this checks good, check the center wheel on the module itself. Two clips keep the wheel in place. If one is cracked off, the IM will not fucntion properly. Other than colder temps, there is no way to adjust the speed of the cycle. Keep the flap in front of the ice-maker down so that the cold air is drawn across that IM. Catriver.
Posted on Aug 06, 2007
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
  • 52 Answers
SOURCE: Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 17, 2008
SOURCE: My Inglis Refrigerator doesn't make ice anymore,
Had the same problem. Chances are that the water has frozen in the supply tube, not allowing water into the maker. you will need to unplug and thaw out your fridge entirely to thaw it out. I used a hair dryer pointed at the filler tube to defrost it.
Posted on Nov 24, 2009
Samusung RFG297HDRS Ice maker not cold enough to produce ice.
Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
Timer ice maker kenmore side
If the timer piece you are referring to is behind the square white cover, and it's moving slightly back and forth, you should visually check the ice making area it's self to see if the ejector fingers are jammed with ice, or against the ice stripper. Ice Maker jams can be caused by reduced water pressure to the unit mainly from the water filter, your water filter in the toe kick should be replaced at an interval of 6 months to a year, regardless of filter status light. When water pressure is low, not enough water fills the unit and the undersized cubes can become lodged or stuck in the ice maker while being ejected, equally so if there is an over fill situation caused by other failures the ice maker can't eject at all. Pleazer Appliance...
Ejector fingers
Ice Stripper
Apr 17, 2014 | Refrigerators
Water does not flow
first you should take the water feed off, clear all water out of tube going to ice maker.remoe ice maker and check the wiring and all looks good.hook water up,turn water on just enough to see you have waterflow yo ice maker.might need a towel or two in the freezer.replace icemaker,make sure bar on ice maker is down,turn water on full,give it 12hrs to make ice. good water flow-no ice--replace ice maker.
Jun 02, 2012 | Jenn-Air JCD2389G Side by Side...
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
Ice maker not making ice. There is no jam and all swithes are in the on position. I think a hose has disconnected, where can I find the hose to check it
Icemaker not working: Check the shutoff arm, the shutoffarm fails to move upward when the ice bucket is full. Check the water pressure. If thereis not enough pressure, the ice maker will not have enough water to make ice.Ifwater flow pressure is good, check solenoid valve activate and also it'scleaned. Locate your ice maker, remove theice bucket. Pull the cover off the end of the ice maker. Locate the holes "V"and "L". Take a paper clip (jump clip) and tape. Straight the clip and put tapein middle. Hold the taped side and insert the clip into "V" and "L". This sendsthe power to water valve. If water goes into ice-maker, water valve is good. Ifnotreplace solenoid. Check thefreezer temperature. The proper freezer temperature should be around 5 degrees.The warmer it is in the freezer, the more difficult it is to make ice. thanks,helpful?
Mar 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Check the shutoff arm, the shutoff arm fails to move upward when the ice bucket is full.
Check the water pressure. If there is not enough pressure, the ice maker will not have enough water to make ice.If water flow pressure is good, check solenoid valve activate and also it's cleaned.
Locate your ice maker, remove the ice bucket. Pull the cover off the end of the ice maker. Locate the holes "V" and "L". Take a paper clip (jump clip) and tape. Straight the clip and put tape in middle. Hold the taped side and insert the clip into "V" and "L". This sends the power to water valve. If water goes into ice-maker, water valve is good. If notreplace solenoid.
Check the freezer temperature. The proper freezer temperature should be around 5 degrees. The warmer it is in the freezer, the more difficult it is to make ice. thanks, helpful?
Feb 02, 2011 | GE GSS20IEP Side by Side Refrigerator
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Icemaker
IT DOESNT MEAN YOU GETTIN WATER IN THE WATER DISPENSER THAT THE VALVE IS OK.MOST FRIDGES ARE FITTED WITH TWO VALVES.CHECK THAT THE ICE MAKER VALVE IS WORKING IF THATS OK YOU MIGHT HAVE A PROBLEM INTERNAL ON THE ICE MAKER BEST YOU GET A TECHNICIAN TO CHECK THAT.GOOD LUCK.MOHAMED
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Fridgeidare freezer
how old is it ??? it only makes 8 ice cubes every 2.5 hrs or so when running correctly.some times 5 cubes depending on model. try reaching into the ice maker and feel the ice being made is the tray full or is there empty slots in the ice mold(asif not enough water). are the cubes hollow??( a sign of low water pressure)). have you replaed the waterfilterrecently (if applicable) old filterwill restrict water flow.
Mar 16, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
