Question about Baby Gear
Stokke changing table 2005 missing nuts and bolts
I have a Stokke changing table dating from 2005 which I would like to pass on to my sister, however I cannot find the fixing kit of nuts and bolts - is there anywhere I can get a pack from ? I think it is called the Stokke Care range
bunnydawg
  • 5158 Answers
SOURCE: I am having difficulty in fixing my stork craft
take the numbers with you or even the part that has the numbers to a hardware store... they should be able to determine what you need. i would suggest buying aircraft type nuts.... they will not loosen on their own which is abit safer. they are not alot more expensive and considering what it is you are putting together they are worth it.
Robert
Posted on Apr 15, 2009
SOURCE: Missing bolts and barrel nuts
First try to find the Instructions online. These will usually tell you what you need. Then call Products America with this information. 1-800-205-9642. I just ordered what I needed for $20.
Posted on Aug 03, 2009
  • 10865 Answers
SOURCE: The crib was given to us but it was missing some
Hello. Yes, the nuts and bolts used for these assemblies are common items found in any hardware store. If you have some of the bolts, take samples with you and ask the clerk to assist you in matching them up. Regards, Joe
PS - kindly rate my answer. Thank you.
Posted on Jan 29, 2010
SOURCE: castors for cot
I rang stokke uk when my castors broke. It took about a week to get new ones via post. Check stokke uk website for contact details they were great
Posted on Mar 13, 2010
jmgldsmth
  • 1869 Answers
SOURCE: I need replacement parts for my crib.
any hardware store will have the parts you need; just take a sample bolt and, nut to them and, they will find them for you. these are not a special part exclusive only to your crib.
Posted on Jul 22, 2010
Testimonial: "Thank you. I did as you suggested and now have the parts I needed. My crib is now assembled."
The brake part of my stokke wheels is broken so now when i put the breaks on the wheel keeps going round, where can i get this fixxed or a repacment part as cheap as posible, thanks
Hi I have the same issue with my Brake - we have called Stokke who say that a full new fishtail (back section that folds in needs to be replaced, the price to do this £180!! Including shipping.
I think i could replace the section in about 5 minutes, but there just doesn't seem to be Parts department anywhere :-( We have our 8 month old using this as her mode of transport just now, since her big sister has outgrown it, so long since passed it's 3year cover period.
Jul 20, 2011 | Stokke Xplory Stroller
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
Mar 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I am just setting up my new Skil bandsaw, and the table is not level--won't go to 0 degrees. Is there an adjustment I'm missing?
usually there is a stop bolt under the table that you can adjust so that you are able to zero out the table. it should have a lock nut so that when you get the table set to where you want it you can lock down the bolt so that the table is easily re set after moving the table for an angle cut.
Mar 15, 2011 | Skil 338501 9inch Band Saw
Jul 22, 2010 | Storkcraft Baby Baby Gear
Castors for cot
Feb 18, 2010 | Stokke Sleepiā„¢ Mini crib
Have a Skil #3305-01 table saw. Need to set blade
The jam nut is on the end of the bolt you are adjusting, directly underneath the table. The easiest way to get to it is to place the saw on it's left side, and move the saw blade to the maximum bevel position (45 degrees). You can then reach up -directly underneath the location of the bolt on top - and access the jam nut.
To be clear - the bolt you are tightening is about 2 inches long with the jam nut on the end with the purpose of tightening the bolt into place once you have established the correct adjusted position.
And yes, the directions for this step were terrible.
Nov 03, 2009 | Saws
Need to change pully
Which One?
60a96c9.jpg The one on the left has two 14mm fasteners 1 nut & 1 bolt. The one on the right has the same 1 14mm nut and 1 14mm bolt. Both are simple to replace. Step 1: Relieve the tension on the pully you wish to replace. Step 2: remove the pully (front) by removing the 14mm nut. To remove the rear tensioner pully, remove both nut & bolt.
May 19, 2009 | Hyundai Motor 2005 XG350
Stokke Xplory Front Wheel
Contact Stokke. They had a recall and they are replacing the front wheels.
Aug 20, 2008 | Stokke Xplory Standard Stroller
Baby Gear Logo
64 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
