Question about Frigidaire FPHC2399KF (226 cu ft) Side by Side Refrigerator
Frigidaire Professional 22.6 Cu. Ft. Counter-Depth Refrigerator - Model: FPHC2399KF I have ice that is collecting in the bottom of my freezer. My understanding is that this ice is caused by a buildup near my unit's defrost unit. I currently have nothing in the freezer portion and I was hoping there was a way to turn off just the freezer and keep the refrigerator side operational. Any help would be appreciated!
  • Phil Lavoie Jul 06, 2010
    Is it easy to remove the panel?
  • Phil Lavoie Jul 07, 2010
    Thanks! I removed the panel poured in hot water into the drain until it flowed nicely. Does this mean that there is a lot of water in my drip pan? Is there anyway to empty this so that the drain doesn't get clogged again?
  • 1,531 Answers
There is a chance that the drain hole is pluged or clogged with frozen ice.This can usually be cleared with hot water to melt the ice then dry off any remaining water with a towel.
the drain is located in the bottom rear of the freezer cabinet just behind the panel with the vent holes
Posted on Jul 06, 2010
Testimonial: "The response was quick. I followed his advice and hopefully my problem is fixed."
  • 1 more comment
  • seth adams Jul 06, 2010
    there is no way of turning off the freezer because all the cold air for the fridge comes from the freezer side of the unit.there is a chance that the evaporator is frosting over to much and this is caused by a faulty defrost sensor and or a faulty defrost timer. but check the drain hole and make sure it is clear
  • pikeax Oct 25, 2010
    I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
    unkink the drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Bloomberg freezer error code e9
Error Code E9 ' Appliance Video
www.appliancevideo.com/repair-help/question/error-code-e9
The unit keeps getting a low water error and everything I could think of checks out: inlet valves, w. ... Error Code E9 ' Appliance Video .... Ice on bottom of freezer
Jul 23, 2015 | Blomberg BRFB1150 | 11.7 cu. ft....
What is error code E3
If you have a gen one (finger ice maker) it means the th3 sensor is open. You will want a trusted technician to tackle this issue.
Mar 04, 2015 | Frigidaire FGTC2349KS Gallery Series 22.6...
How can I deterine if there is a problem with refrigerator, and not the power line, when the 'Power Failure' alarm keeps going off?
Hi friend, that's a great question!
I understand that your refrigerator FPHC2399KF is consistently reading a power failure. It might possibly be an issue with the control board or with your power source. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair.-Matt
Jul 18, 2014 | Frigidaire Professional Series FPHC2399KF...
My refrigerator is beeping and has high temperature both (freezer 30F and refrig. 58F). I try to set to default, but it didn't change.
your coils down at the bottom may be dirty & full of dust vacum it out. if the there is ice forming in the freezer it needs to be defrosted.
Oct 28, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Ice keeps building up in bottom of freezer and on vent inside fridge and now fridge won't stay cold.
Clean the coil inside the rear access panel behind the unit with a spray air duster and check for this problem.
Jun 14, 2010 | Frigidaire 22.6 Cu. Ft. Counter Depth...
Water puddle on floor from inside refrigerator could it be defrost heateris bad? water accumulates in the bottom of freezer and freezes seems to come out of evaporator/fan location
Jun 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frig not stayng cool. Freezer not freezing
most fridges have a evaporator dish or container.
it must be emptied ...and cleaned and disinfected.
now-a -days they are usually mated with the compressor and cool this unit down. notice there is no coil along the back of the fridge...it is usiually behind the fridge at the bottom with a cardboard or plastic access cover...
this will make the unit cool better and return the cooling to normal....
\next
clean out your freezer...i bet it's full of 4 month old packs of something you'll never eat....this will let the freezer breathe and circulate air to the coil ...i bet it has 3 in of ice on it...yikes...your not alone...most people do this...\
get a freezer if your getting ready for the apocalypse and liberate some room.
good luck
May 18, 2009 | Jenn-Air Jenn Air Side by Side Counter...
Frigidaire FPHC2399KF (226 cu ft) Side by Side Refrigerator Logo
210 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
