Question about JVC XV-FA900BK DVD Player
Carosel will not open
No disc's inside power light on will not open
    President:
  • 1,099 Answers
you can fix this by opening the back cover of the DVD player to check for the rubber attached to the motor of the mechanism , if it is slack , if it is , you replaced the rubber to size that will match with the motor, if otherwise you have to replaced the complete mechanism .
Hope this helpout .. Good luck.....
Posted on Jul 06, 2010
Sony CDP-CX455 carosel is getting stuck when trying to go to a numbered disc. I hear belt screeching and the carosel goes back and forth a few disc, but not where it suppose to go.
The belt is stretched/worn and needs to be replaced. In some cases an O--ring can be substituted. Got mine at a hardware store that still carries plumbing supplies.
May 18, 2016 | Sony MegaStorage CDP-CX455 400-Disc CD...
Sony Compact disc player CDP-c705 carosel will not open
There may be a disc stuck inside but carousel-type CD changers are trouble-prone.
Jun 20, 2014 | Sony Audio Players & Recorders
My DVP-NC600 CD/DVD player will not recognize discs inserted. The carosel just spins freely and won't stop. HELP!
Welcome to fixya!
open up the screws , if you can check the tray if there is something inserted remove it and its ready to be used again ,
the reason is something is struck inside it may be a disk or something .
Check if helps you in any manner
Apr 30, 2011 | Sony DVP-NC600 Multi-disc DVD Player
My wurlitzer 1015 cd jukebok carosel continually
There's a little light like a torch bulb light called the "light gate lamp" which you should be able to see shining at 6 oclock on the edge of the record carousel. It is on the lip where the serated toothed edge of the carousel passes through a small upright bracket. If you can't see it shining then that's your problem. Have a look in the original documentation and it shows a diagram how to change it.
Dave.
May 22, 2010 | Wurlitzer Jukebox 1015 One More Time...
Discs have been dislodged form the unit - How do I open the unit
Have to remove the top cover and carefully
remove all the cd's without scratching them!
Should operate normally after that!
Apr 20, 2010 | Sony MegaStorage CDP-CX355 300-Disc CD...
Lights fan and carosel do not work
tricky one. common denominator to all parts not working could be open neutral track at back of the circuit board, or possibly a relay not switching correctly.Need testing equiptment for that.
Sep 13, 2009 | Microwave Ovens
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
Sharp Carosel R-1481 (no B) & 950 Watts
All MW has a fuse inside to protect the circuit board
Try to replace the fuse
May 10, 2008 | Sharp R-1481B Microwave Oven
Tray won't open
Have a professional open it up to check so not to further damage the device. If you want to do it your self, you can open it up, just make sure your warranty is not void by doing so...
A possibility is that the tray has a lodged cd in it...
Dec 10, 2007 | Onkyo DR-C500 Multi-disc DVD Player
Error code H01
I opened up by Panasonic dvd-cv52, which I purchased in Dec 2002 for H07.
The H07, based on research, indicated that the spindle motor had an issue, a post I found suggested trying some 3-in-1 oil.
I tried this and it worked (note, pop the top off firstm then power up the unit, then press the open button, then unplug the power, this will make it easier to lubricate).
Once I had done this and powere back up, I got h01.
Turns out I neglected to put back the elastic that is used to spin the carosel for the dvd's (I have a multi dvd player).
I would check to see if there is an elastic in place to spin the carosel, maybe your broke (assuming you have a multi carosel also)
Good Luck
Louie Whote
Oct 27, 2007 | Panasonic DVD-CV52 DVD Player
JVC XV-FA900BK DVD Player Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
