Question about RCA HD52W56 52" Rear Projection HDTV
Colors are seperated
Red, blue, and green lines. looks almost like 3D picture.
  • 58 Answers
This is an ITC222 chassis. Very common for broken pins under flyback to cause this. Resolder flyback and replace adjacent 400ma fuse. It's a little red box, there are 3 in a row and the one that blows is the middle one. If this does not repair, suspect the convergence power supply. It's the vertical board above the power supply. I've replaced the power mosfet on that a few times as well. And remember if there's any doubt contact a professional. Goodluck.
Posted on Jul 06, 2010
SOURCE: Colors are not in line together, 3D look
hi, You most probaly have a problem with your convergence, goe into menu locate convegence try and adjust and see if there will be any changes, if not i sugest it be done by a profesional. zazwpx
Posted on Jun 05, 2007
yankeegurl
  • 121 Answers
SOURCE: Color doesn't line up
you need to replace both convergence ic's they are located on your D board mounted right on the 2 big heat sinks you should either need STK-392-560 or STK392-510's you can find which one on stamped on the side of your old ic's. you can go to this sight and get them at reasonable prices plus picture installation instructions and free online tech support if you need help. By doing the repair yourself you will save between 4-500.00 for about a 45min repair
http://servicemanuals.vstore.ca/
Posted on Apr 25, 2008
localwonder
  • 6784 Answers
SOURCE: The colors are distorted and it seems like the
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Posted on Mar 08, 2009
  • 13 Answers
SOURCE: 3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Posted on Oct 14, 2009
welcomejee
  • 10594 Answers
SOURCE: the colors are seperating making it look like 3d
This is symptom of convergence output chips failure in rear projection tv, replace convergence ouput ICs in tv to get it fixed.
If you are handy with electronics stuff repair and can solder parts in circuit board then check 2 big black ICs mounted with aluminum heat sink on D board of tv, replace them with same numbers and if you feel uncomfortable working with tv circuit boards, local tech will help you.
Thanks.
Posted on Mar 31, 2010
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
The picture looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Color is splitting, and almost looks 3D.
the ITC222A convergence option missing repair kit at the following link should repair that issue. The kit contains the parts and the instructions on CD
http://www.tvrepairworld.com/
Jul 19, 2009 | RCA R52WM24 52" HDTV Projection Television
Pictures look like they are in 3D
it sounds like your convergence is off.
you have Red, Greed & Blue projection guns
through your menu's you will find adjustments for them ...
set your green first then align then red and then blue to the green..
when making this adjustment the tv should put up a caliration signal called a crosshatch
a matrix of H and V lines to align
Apr 15, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Akai PT4298hd
You may need the change the coolant in the blue tube. Convergence is when the picture will look 3D Let me know if you need more information.
Apr 25, 2008 | Akai PT4298HD Rear Projection Television
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Red green and blue lines
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
114 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
