Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is making weird noise
My ice maker is making this weird noise... Its very high pitched, continous and the only way I can think to describe it is like someone stepping on the gas then letting off then stepping back on it.. it never stops. It's driving me insane. Please help!!
If it gets louder when you open the freezer door, and seems to be coming from the rear wall (about 2/3 of the way up), then it is probably not your ice maker. It is your evaporator fan motor, which can't really be serviced. The good news is that it isn't too expensive, and it is fairly easy to replace.
Posted on Apr 21, 2008
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Do not use ice maker and it makes noise
What is the complete model number of your unit?
Nov 25, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
I have a Jenn Air JRSD209W refrigerator. The ice maker stopped making ice. So far I have replaced the water supply solenoid and the ice maker unit. The unit is cycling mechanically, but no water is...
Check the water line that goes from the water fill valve to the ice maker to see if it's frozen shut.
You can remove the ice maker water line from the water fill valve and see if you can blow air through it. If you can't blow through it then its frozen shut.
Sometimes they freeze shut if the water inlet valve was seeping a little water past it when it was off.
If that is the case you have already replaced it so after thawing the water line out you should be good to go.
Aug 03, 2011 | Jenn-Air Refrigerators
Water leak on back wall of my freezer and a hell of noise from my icemaker when on
Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
  • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
  • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
  • The high-efficiency compressor may make a pulsating or high-pitched sound.
  • Water running over the evaporator plate may make a splashing sound.
  • Water running from the evaporator plate to the water reservoir may make a splashing sound.
  • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
  • You may hear air being forced over the condenser by the condenser fan.
  • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
  • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
Hope, it's helpful>
Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
U-line model ulr-60b
hi,
periodical clean can smooth the operation of your ice maker.
at this link you can have the ice maker cleaning guidelines:
http://lib.store.yahoo.net/lib/usappliance/echelon-icemaker-manual.pdf
Sep 09, 2008 | U-Line Refrigerator Ice Maker
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
Nov 06, 2007 | Jenn-Air JCD2389G Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
272 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
