Toshiba m52 laptop
Hi computer comes up with the error it says computer has hadf power fai luer or reset button was pressed but it will not re start when enter button is pressed how do i reset start any body can help please ian
    Problem Solver:
  • 5 Answers
Heya tomcat..
try turning it on and off at the main switch. If the power failure had caused issues with the HDD or system, Windows would do a scan after you boot up..
Jason
Posted on Apr 27, 2008
How to factory reset toshiba notebook a45s250, the laptop wont reboot to windows after install in partition d, partition c is still installed but it wont boot in either one of them
Cordoba, Try holding the Zero button down and press the power button once,continue/ still hold Zero button till computer starts.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Factory reset almost ANY Toshiba laptop
Toshiba Satellite A45 S250 Manual
FAQ How do reset my computer back to factory default state System Recovery...
Jul 29, 2016 | Toshiba Computers & Internet
How to reset Toshiba e studio 207 photo copier c43 error
Press and hold 0 and 8 buttons and switch on the power switch and release the two buttons after display comes on, then put 400 with the numeric keys and press start button then press 0 button once and then press enter button, then switch off the power and switch it on after 2 minutes. If the problem occurs again replace the Thermister and follow the same procedure to reset error code.
Good Luck
May 04, 2016 | Toshiba Office Equipment & Supplies
Toshiba studio 181 error c44
This error indicates that the print count has gone above the limit and it requires service. But, this is not necessarily true. Try the following to reset the count:
Solution:
  1. Switch off the printer first.
  2. Now Power the Printer by pressing 0 and 8 keys (keep pressing).
  3. Then a test mode comes up.
  4. Now Type 400.
  5. Press START (!)(You will get a counter and now you need to reset this).
  6. Type 0.
  7. Press Enter(start)
  8. Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
  9. Now switch off the printer and on it normally.
  10. You should see printer working normally
Resource: Clear Toshiba eStudio printer error message Error C44 call service
Jul 23, 2014 | Toshiba Computers & Internet
Laptop is run and start but no display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
The laptop will not come on?
Hi.
Try a hard reset. Sometimes it works and is always the first step to take. Remove the battery and the ac adapter plug from the laptop. Press and hold the power button for forty seconds. Install either the battery or ac adapter power and press the power button toattempt a boot into the OS.
Hope this helps. Shiboram
Sep 18, 2011 | Toshiba Satellite Pro 4600 Notebook
How to go back to factory settings
All data will be erased on your hard drive if you proceed. Make sure that the power wont be interrupted during this process. Do not switch off or restart your computer either.
-Shut the computer down completely
-hold the 0 (zero) key down and at the same time press the power on button release the power when the machine turns on
-when the computer starts beeping release the 0 key
-when the prompt comes up choose YES to continue with system recovery
-Select recover of factory default software and click NEXT
-Click Next again to start recovery
Hope this helps!
Apr 14, 2011 | Toshiba Satellite Pro L300 Notebook
I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
Can not turn the laptop on
Hi. Turn the computer on and press F8 when you see the toshiba screen. Select safemode then press enter. open the System Config Utility (msconfig) by pressing Start, Run (XP), or type the word msconfig then press enter for Vista.
Disable all start up items and restart your machine... See if it starts and boots to windows.
^_^
Jun 04, 2010 | Toshiba Satellite A205-S4617 Notebook
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
Toshiba M305-S4819 laptop won't turn on. After
check first the chager is working or not, then power button, after that dc connector.. if its okay motherboard problem need to check th MB then fix it..
Sep 10, 2009 | Computers & Internet
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
