My laptop IBM thinkpad 430, keeps getting a error message, ati2dvag display driver not working,and I have to restart computer-- I installed new driver,is it graphic card?
    President:
  • 1,561 Answers
I advice you check the service manual that came with your device, the solution to the prescribe issue should be address in the service manual, using this will be of good guide.
Take care.
Posted on Jul 14, 2010
Had to reformat my windows xp professional on my thinkpad 40 2722. Works beautifully- a clean restart but lost my drivers and cannot get to internet. How do I get the needed drivers back?
If your laptop comes with a driver CD, you can use that to install the needed drivers. If not, you might need to use another computer and go to IBM Thinkpad support website and download the drivers from there. Save it on a USB thumb drive and use that to install the drivers to your Thinkpad.
Go here for the IBM Support Website
Hope this helps.
Sep 08, 2011 | IBM ThinkPad R40 2722 Notebook
Hello i have a ati radeon 9250 and windows 7 it havent driver for windows 7 therefor i installed driver for windows xp in windows 7 all work good but in shutdown or restart i have blue screen...
The way to fix ATI2DVAG.dll errors is to first restart your PC into "Safe Mode With Networking". This will basically allow your PC to boot up without all the drivers and software which can cause it to crash. To do this, you should first restart your PC and then press F8 continually before Windows loads. After that, you should then select "Safe Mode With Networking" to boot your PC into that mode. When in safe mode, you should download a new version of the ATI Graphics Driver from the Internet, which should fix most of the problems you've been having with it. This can be done by downloading the driver from the ATI website and then re-installing it in Windows.
After updating the driver, try your PC in "normal mode" again to test to see if the problem has been fixed. If you find it hasn't fixed the issue, you should then go back into safe mode an manually replace the ATI2Dvag.dll error on your PC with a fresh copy of the file from the Internet. On top of that, you should also clear out the "registry database" of your PC with a registry cleaner. The registry database is a central storage facility for Windows, which basically keeps all the settings and options that Windows needs to use to run inside. This part of your system is very important and used to load up many different DLL files. To ensure no registry errors are causing problems on your system, you should download a registry cleaner program from the Internet, install it and then let it fix the errors your PC has.
You can fix ATI2Dvag.dll errors on your PC by using the tutorial and tools on our website. You can Click Here to fix ATI2Dvag.dll errors on your PC.
OR
Do not download ati2dvag.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of ati2dvag.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the ati2dvag.dll error.
Restore ati2dvag.dll from the Recycle Bin. The easiest possible cause of a "missing" ati2dvag.dll file is that you've mistakenly deleted it.
If you suspect that you've accidentally deleted ati2dvag.dll but you've already emptied the Recycle Bin, you may be able to recover ati2dvag.dll with a free file recovery program.
Important: Recovering a deleted copy of ati2dvag.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
Run a virus/malware scan of your entire system. Some ati2dvag.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the ati2dvag.dll error you're seeing is related to a hostile program that's masquerading as the file.
Use System Restore to undo recent system changes. If you suspect that the ati2dvag.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
Reinstall the program that uses the ati2dvag.dll file. If the ati2dvag.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
Important: Try your best to complete this step. Reinstalling the program that provides the ati2dvag.dll file, if possible, is a likely solution to this DLL error.
Update the drivers for hardware devices that might be related to ati2dvag.dll. If, for example, you're receiving a "The file ati2dvag.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
Note: The ati2dvag.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
Roll back a driver to a previously installed version if ati2dvag.dll errors began after updating a particular hardware device's driver.
Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the ati2dvag.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The ati2dvag.dll file could be included in one of those updates.
Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause ati2dvag.dll errors as they fail.
If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
Repair your installation of Windows. If the individual ati2dvag.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
Use a free registry cleaner to repair ati2dvag.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid ati2dvag.dll registry entries that might be causing the DLL error.
Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the ati2dvag.dll error, this should be your next course of action.
Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the ati2dvag.dll error using a troubleshooting step prior to this one.
Troubleshoot for a hardware problem if any ati2dvag.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | ATI Computers & Internet
I'm having a Lenovo T61 Thinkpad. All of a sudden my laptop keeps turning black. I keep getting the error message that display driver stopped working but recovered successfully but this may not always be...
Hi. I think you have uninstall your display driver and download the updated drivers on the Lenovo driver support website.
Go to this website and download the video driver for your laptop: http://www-307.ibm.com/pc/support/site.wss/product.do?doctypeind=9&template=/productselection/landingpages/downloadsDriversLandingPage.vm&sitestyle=lenovo
just make sure that you choose the correct or corresponding operating system that you have on your laptop (e.g XP, VISTA or Windows 7)
After downloading the video driver install it on your laptop then restart you computer. Goodluck!
Jun 13, 2010 | Lenovo ThinkPad T61 Notebook
Ati2dvag infinite loop how do I fix this
This seems to be a problem with the video card driver as ati2dvag is a part of it. What you could do is go into safe mode. Insert the drivers disc for your video. Reinstall the driver for your video card.
To go to safe mode just restart the computer and continuously pres f8 until you see the advanced options menu then press the arrow keys to highlight safe mode. Then press enter.
Apr 29, 2010 | Toshiba Satellite A60 Notebook
Windows 7 - blue screen error: ati2dvag.dll
try to re-install driver of your video card , it should be supported by windows 7
Nov 09, 2009 | Microsoft Computers & Internet
Problem regarding audio driver
XP drivers from here
http://www-307.ibm.com/pc/support/site.wss/MIGR-58599.html
According to IBM website Vista drivers from windows update.
Sep 13, 2009 | IBM ThinkPad R52 Notebook
Ibm thinkpad t21 only have 16 bit color and 800 x 600 pixels. looks like its in safe mode but its not.
Check video drivers. Download new one, uninstall old drivers, restart computer, install new drivers, restart computer.
Then right click on desktop -> propertites -> display.
Aug 08, 2009 | IBM ThinkPad T21 2648 Notebook
My ibm thinkpad t43 displayed a message "hard error D0014" on a small blue screen. when i shut it down by pressing the power button for a few seconds, it restarted. but the programs won't work.
This could be a problem, not sure if its a software related or if the hard drive is bad. If you can find a windows xp cd. Try and wipe out the hard drive and install windows xp on it. If it goes thru then you'll just need the drivers. If it errors out on you then you know its a problem with the hard drive and you'll need to replace it. If you get windows xp installed on it, let me know and I'll help you with the drivers.
Jun 04, 2009 | IBM ThinkPad T43 Notebook
I keep getting this message "thermal sensing error"
That same thing happened to me this morning and when i did my research I notice it only happens to Lenovo brand Laptops. You need to get a new CPU. I was horrifed to know that because it's not my laptop.
Jan 11, 2009 | IBM ThinkPad R40 2681
No sound
Start with this.....................
  • double click the sound icon located down the right corner of your display.
  • uncheck the option if any is muted.
  • slide all the volume/options to the top.
If the above options yield nothing try this........................
  • uninstall the sound device at the control panel.
  • restart the computer.
  • you will be asked to install a new found hardware, click next till to the end.
See the results, if fail too try this..........................
Let me know if all those worked or not.
Jan 20, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
