Question about Maytag Refrigerators
I have a magic chef fridge that the coil keeps
I have a magic chef fridge that the coil keeps freezing up. The drain is clear and I have installed a new defrost timer. Any suggestions?
    President:
  • 1,218 Answers
Good day,
The defrost system is made up of 3 parts. The timer, the defrost thermostat and the main heater.
The most common item to fail is the defrost thermostat which is clipped to the top of the cooling coil, located behind the rear panel in the feezer problem. It looks like this.
It can be tested with an ohm meter and should read zero ohms.
It must be tested while still cold. If allowed to warm up the test will fail. If it tests O.K. then the only item left is the main heater.
It will usually test at less than 35 ohms. If it test infinity, then it will have to be replaced.
It may be a single heater or a set of 2 but without the model number I cannot give you that information.
Posted on Jul 06, 2010
How do I clean the condensate drain on a Magic Chef fridge mod #ctb1521grw
if not mechanically inclined, call service tech. you could clear by blowing condensed air from drain line outlet, or attempt to disassemble and clear drain from evaporator drain pan
Apr 01, 2015 | Magic Chef Refrigerators
The problem is with my magic chef top/bottom fridge/freezer. the freezer is working fine, but the refrigerator is freezing its contents.
Either defrost problem or clogged drain... Is there snowy frosty ice on back wall in fridge? If so, hire a professional. If not - you can take back wall off in the freezer and defrost the drain.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Magic Chef CTB1521 Top Freezer...
I have a magic chef refrigerator model ctb1923aba and it leaks water down the back wall and out the front below the crisper bins. I am pretty sure it is a partially blocked drain tube. I am having trouble...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 17, 2011 | Magic Chef Refrigerators
My magic chef rb193p fridge wont stop running. I replaced the fan motor 4 months ago. The top of the fridge compartment is freezing. Is the defrost timer bad?
I had the same problem. When the evaporator heater stops working, frost will build up until there is no air flow to the refrigerator. This will cause the refrigerator to keep running. Remove everything from the freezer and remove the pan at the bottom and see if there is a frost buildup. .... Bruce
Jun 18, 2011 | Magic Chef CTB1922 Top Freezer...
Magic Chef Fridge not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
709oy
Jul 07, 2010 | Magic Chef CTB1722 Top Freezer...
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
What would cause the inside top of a Magic Chef refrigerator model RBK21K-2A to freeze up and not keep items in the refrigerator compartment cold (temp doesn't drop below high 40s)?
lack of sufficient air flow across the evaporator coils, clogged condensate drain, too much humid air (door open too much, bad seals, etc.), low refrigerant.
Aug 07, 2009 | Magic Chef Refrigerators
Freezer not Freezing
the air flow is blocked betwen fridge and frezer or even the small fan is burnt out
Jun 22, 2009 | Magic Chef CTF2125 Top Freezer...
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
