Question about Sony Playstation 3 (PS3) Console
My Playstation 3 Does not work for 2 of my Flat Screen TVs. Particularly Phillips Flat screens. How do I fix this? Joe
    President:
  • 1,099 Answers
You hold your finger on the power button for about 5 seconds. After two beeps it resets it to the RCA cable format. When the HDMI cable is connected, the PS3 automatically adjusts it's resolution. But when you go back to regular cable it doesn't do it automatically, you have to do it manually.
Hope this helpout.....
Posted on Jul 06, 2010
  • joe_c_anders Jul 06, 2010
    The Playstation works in my bedroom on my RCA Flat Screen but for the others the screen stays black.
    Joe
Phillips 55PFL5705DV/F7 Video went out Audio & backlight work fine. Switched TVs & all devices work so it is the video on Phillips. Any ideas
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 21, 2016 | Televison & Video
Polaroid tlx 04240b. hello, my polaroid flat screen 04240b turns on, watch tv but a bunch of lines are on the screen. what is that. is it worth it to fix. thank you, joe
There is many reasons for this fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
http://electronicshelponline.blogspot.com/ Screenshots to defective LCD panel is given with illustrations. You can compare the to that of your TVs, and can make sure about the fault. Pictures can talk more than words.
Gopakumar Gopalan Google
Feb 19, 2014 | Sony Televison & Video
Phillips TV Model: 52PFL7422D/37 Purshased this TV Dec 16, 2007. No I have blank screen with the TV blinking a read light at the left - the red light flickers - blink, blink,blink,blink,blink then 3...
First place to check is the power supply board. I have not repaired this particular model. I'm very certain you have two bad capacitors in the power supply. This is a classic problem for Philips flat TVs. The capacitors will be bulged or skinned. Be sure to replace them with same values. I would certainly gamble my time removing the power supply for inspection. Spending a few bucks on two capacitors may prove good. A working TV is near. Thanks for asking and show all hands of support!
Jun 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
I have 2 Flat screen Phillips TVs a 47" and a 20" for my camper. I bought a set of rocket fish wireless speakers for use in my camper. I can not receive audio from the tvs to the speakers. The...
the sender plugs into the TVs audio out jack and you may need to select on a on-screen menu for the TV, audio out for the external speaker, in other words, the tv speakers are activated but maybe not the external audio jack for the sender unit. Many HDTVs have a very complex menu (firmware) with all kinds of options you can select. Check into this possibility.
May 06, 2011 | Philips Televison & Video
HD programs work fine, however, the standard pictures are distorted. I had this once before and someone fixed it but not sure how.
You probably need to to turn your aspect ration on the TV down. Newer HD screens use a 16:9 aspect ratio for HD content which is a wide screen format. Standard definition TVs and programs use a 4:3 aspect ratio. Most flat screen TVs have an option to display in 4:3. This option is most often found in Menu/Setting>Video Options>Aspect Ratio. For standard definition programming you want 4:3, for HD you want 16:9.
May 05, 2011 | Televison & Video
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    I have a Westinghouse 32"
    These TVs are notorious for backlight inverter problem. You could look for a complete backlight board(this will be easier if you're not a tech), or you can replace the transformer and transistor(transistor doesn't always go - sometimes you get lucky). The transformer that is bad will have a small burn mark in it where one of the legs comes up from the board. If I was you I would just replace the board since it's easier. I have done about a half dozen of these. Joe
    Nov 12, 2010 | Westinghouse Televison & Video
    I have 2 Polaroid flat screen tvs. The 19
    A trip to the dump may be the most cost-effective answer.
    Jul 19, 2017 | Televison & Video
    Our 52 inch Phillips Plasma tv is not working
    open the back of the set and inspect the power supply board -- there should be two fuses on the board- they cost around 2 dollars at radio shack -- check all connections for wear or damage -- there are two boards in most televisions -- a power supply board and a audio / digital board -- one is probably board
    Feb 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
    Cannot get my HDMI cable linked from my ps3 2 my hd tv
    Try video settings on the playstation 3. Adjust it to reflect hdmi.
    Feb 22, 2009 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
