Question about Whirlpool Duet GHW9150P Front Load Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
    Scholar:
  • 154 Answers
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Posted on Jul 06, 2010
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
Why does my whirlpool frontloader stop in the middle of a cycle and read f 02
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 06, 2014 | Whirlpool Washing Machines
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
Problem with whirlpool w/m adp4737
Whirlpool Duet & Duet HT & Kenmore w/110 model prefix Frontload Washer Error Codes-OLDER
  • F/H--No water detected entering machine or Pressure switch trip not detected
  • F/02--Long Drain
  • F/05--Water Temperature Sensor Error
  • F/06--Drive Motor Tachometer Error
  • F/07--Motor Control Unit Error
  • F/09--Overflow Condition
  • F/10--Motor Control Unit (MCU) Heat Sink Thermal Trip
  • F/11--Serial Communication Error
  • F/13--Dispenser Circuit Error
  • F/14--EEPROM Error
  • F/15--Motor Control Unit (MCU) Error
  • Sud--SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • F/dL--Door Lock Error
  • F/dU--Door Unlock Error
Jan 01, 2012 | Washing Machines
Whirlpool Duet Sport won't work past the wash cycle. It's full of water and will not drain.
check the pump filter it could be blocked or the drain hose try blowing down the drain hose to see if its clear you should hear a bubbling sound if not its blocked
Nov 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet frontload washer not draining on automatic cycle
Try unplugging for 10 min. This will reboot the system and clear the curcuit of all power. Replug the washer and select spin to drain. Selecting too many cycles in a short period of time can confuse the little brain in the curcuit just like a power surge does after a storm. Clear the brain and start from scratch.
Apr 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
Frontloader washer
make sure your drain hose is above the tub in the washing machine
Feb 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
240 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
