Question about Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit
RESETTING A couple of times my unit needs to be reset, when i go into the menu option i don't seem to have the FM module option that will allow me to search and change frequencies, why can I not see that option?
  • stareyes Sep 09, 2008
    I don't have the FM module option that will allow me to search and change frequencies, either. Why can I not see that option? I am trying to reset frequency because I am not getting any audio. Everything has been checked, but no audio and no option for the FM module. I can not even get to "vehicle mode"
  • Anonymous Dec 05, 2008
    Ours freezes occasionally because we live up north
Try unplugging the radio and plugging it into another electrical outlet. We did that and it worked.
Posted on Dec 06, 2008
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
Cannot change the language to english it is currently japanise
looks like you have to reset it
to do that slide the hold button to hold and then back
then press and hold the menu and the center buttons at the same time for about 7-8 seconds until the apple logo shows on screen
if after resetting, the language is still Japaneses, then do this
Scroll down to the last menu option but don't select it.
Scroll up one menu item. This should be Settings.
Press the Center (Select) button. This takes you to the Settings menu.
Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
Scroll up to the third menu item from the bottom one. This should be Language.
Press the Center button to select Language.
Select your preferred language from the list.
Jul 18, 2011 | Audio Players & Recorders
My AIWA cd-x444 unit is stuck in some kind of dealer demo mode, and not the demo mode that you can program the unit to enter from the menu. In this mode, whenever the unit is on, it flashes through all of...
it sounds to me like you may have a bad switch. sometimes if you get a switch that does not open all of the way, it sends a message to the microprocessor and locks it up. when this happens, the switch needs to be replaced.
Mar 10, 2011 | Aiwa CDC-X444 CD Player
Menu options pop up w/out me touching it. won't go away keeps popping up
Hello there id try Fully resetting the power to the unit if that doesn't seem to work check to make sure the menu key is not sticky if it is make sure the unit has no power and clean the menu key.
Jan 23, 2011 | Toshiba 32A43 32" TV
Not focusing, picture is blurry, lens goes in and out, tells me to turn on and off
This seems to happen when the Lens unit in the Camera is stuck and not retracting. The possible troubleshooting steps to resolve this issue are power resetting and factory resetting.
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset:(This can be performed only if the Menu of the Camera is accessible)
To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.
Home-->Settings-->Setup 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Handset Fails to Register
It is quite possible that you'll need to go into the menu settings on your base-unit and reset the unit or restore factory default, whichever option it gives you. Also, look in the menu on the phone to see if there is an option to reset the handset also. After resetting the unit and/or handsets, try to register the handsets again, one at a time. If that still does not fix the problem, you may have handsets that are not compatible with your system, or your system may not be able to support that many phones. However, if you have the right handsets, and your system can host that many handsets, then I'm confident that resetting the unit and re-registering your handsets should fix your problem.
Hope this helps! Have a nice day!
Apr 05, 2008 | Uniden DCX640 Cordless Expansion Handset...
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
Roady XT Transmitter problem
Mine is doing the same as well. Been working for 1 year. Now it starts cutting out while listening. I noticed if it is broadcasting the fm frequency menu is there. The minute it cuts out I press Menu and that menu item is gone. It comes back once the radio starts working again. Mine is 1 year old. I got it Christmas of 2006. I do know that if you have it directly connected then this menu item will not appear and that is by design. I think my xm roady xt has gone bad.
Jul 02, 2007 | Delphi Roady XT XM Radio Receiver
Delphi XpressRC XM Satellite Radio Receiver with Vehicle Kit Logo
492 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
