Question about Danby DFF1144W Top Freezer Refrigerator
I have a small danby fridge DFF1144W.After each time the doors
Are opened and closed there is the sound of water running inside the fridge and it is loud.No water comes out just the sound of water running down a drain loudly. Any suggestions?
Falling Down
  • 67 Answers
SOURCE: Danby DDW1802W Cycle Problems
The fill valve is probably stuck in the full position. It's at the bottom of the tub and looks like a small tube with a cap on it. You should be able to move the cap up and down easily.
Posted on Nov 30, 2007
SOURCE: Danby Silhouette leaking
Unplug your device, clean the mess and remove the filter.
After you have cleaned out the filter, remove the water tank. Inside of the area where the water tank was at the top you will see a small opening (drain) which is where the water comes from. It is probably clogged...
Take a few Q-tips and clean the inside of it. There is still probably water trapped inside so expect more water to come down as you do this. Once you're satisfied that the small drain is cleared, you can put everything back together and you should be good to go!
I had the same problem and that fixed it.
Posted on May 15, 2008
  • 3 Answers
SOURCE: Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Apr 13, 2009
I had the same problem, and found it to be as RonLew described. In our case it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Posted on Jun 13, 2009
  • 340 Answers
SOURCE: New unit has loud noise & doesn't drain. Too late to return!
drain line kinked? trying to diagnose a noise problem over the inter net really hard . could be compressor
Posted on Jun 17, 2009
DFF1144W
Check condenser is clear and clean, and fan working. If all else as should be, suspect becoming short of refrigerant
Apr 21, 2014 | Danby Refrigerators
My refrigerator stopped working because I left the door open for like three hours and the electricity does not go to all the fridge parts like the lighting system is off and the freezer is off every thing...
There is no sensor like you stated. Actually, when you keep open the fridge door, the cooling all will go out and hence thermostat sensor would not cut off, as required temp not reached inside the fridge.
So, the compressor would have run for long time without cut off. Due to this the overload protector trips the compressor. Remove power for 4 to 6 hrs. And then restart the fridge. But make sure you close the fridge door. Thanks.
Mar 20, 2011 | Danby Compact Refrigerator DCR-101W
My brand new Beko frost free fridge freezer makes a loud gurgling noise and sounds like water trickling inside every time the fridge door is opened then closed again, regardless of how long its open for....
mINE IS DOING EXACTLY THE SAME - I'VE HAD IT ABOUT 2 WEEKS BUT ONLY STARTED MAKING THIS SOUND TODAY AND AS YOU SAY ONLY WHEN THE FRIDGE DOOR IS OPENED AND THEN SHUT!
Oct 08, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
We have an older model Danby D730, it is freezing on the back part inside of the fridge. We realize there is no more around, is there anything that we can do to save it.
Sounds like defrost problem. Could be fan motor, Defrost timer,or defrost heater. Try turning off for 8hr to melt ice then turn back on.If it runs and maintains temp for 24hr check and repair defrost Problem.
Sep 06, 2010 | Danby 11.4 cu. ft. Frost Free Generation...
How much tempature in the fridge should be to keep milk ok
33F - 40F (1C - 4C)
37F is default setting in most refrigerators.
Dec 18, 2009 | Danby DFF1144W Top Freezer Refrigerator
WATER DROPS AT TOP OF FRIDGE
sounds like the door was left open,make sure nothing is overhanging on the shelves preventing the door from closing next time send model number
Nov 27, 2009 | Refrigerators
I have a magic chef ctb2124arb refrigerator and periodically we have water running down the inside. I checked the drain hose in the back of the unit and it is clear. thanks.
check that the door is closing up tight, if its even just a little bit open it sucks in hot warm air and when this cools it has a lot of water in it, this is were the water is coming from, also if the door is open a lot of times a day that will cause it too, some people leave there fridge door open every time they get things out of there fridge and dont close it untill they put the stuff back in? and all the cold air has fallen out the bottom by then,,so the poor fridge is working its head off and getting no were fast,
Nov 19, 2009 | Refrigerators
A funny smell and i think it might be the temperature
Adjust the knob to 3 or 4 which would be the midway temperature.
0 would probably be off or close to it. The 7 would be coldest and freeze water.
If this is manual defrost you need to turn it off and defrost it. The frost will keep it from getting cold enough. The buildup is normal from humid warm air when opening the door. You might get a standalone fridge / freezer thermometer (about $5) to tell you what temperature is. The smell may be food spoiling from warm temperature.
Mar 20, 2009 | Danby DDW1805W Designer Series...
Thermostat
It's the Danby "auto-defrost" feature. It cycles off every 24 hrs to defrost, at which time the temp rises (as the unit isn't running!). Not much you can do. By the way, the blue LED temp display isn't accurate. It NEVER gets 36 (liquid temp) inside the Danby unless you do the following: Open the door and look to the back left. There is a small grate covering the temp sensor. Remove the grate and place the sensor into a small cup of water. The sensor will now read the "liquid" temp inside the keg, and not the "air" temp. The Danby will then cool the inside to a more beer friendly temp, and should not only cut back on foam, but taste better.
Sep 03, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DFF1144W Top Freezer Refrigerator Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
