Sony KP61HS10 and timewarner digital cable box. Don't know which is the problem. Problem is a blue/white ghost on all channels. Tried unplug both units, tried flash focus. Shadow/ghost is now curved image instead of straight image. Ideas of which product needs looked at? If tv, idea of what it is and approx. cost? Thanks.
  • buglete Apr 18, 2008
    thank you. figures it is tv and not box. box cheaper to fix (trade it in for new one). any idea of costs ?
  • 4,234 Answers
I'm going to guess that these ghosts are of different colors too. This is most likely a convergence problem. Try resoldering the pins on the convergence ICs first. If that fails, replace them.
These ICs are large and black, attached to a heatsink. They will be marked STKxxx.
Keep us posted.
Dan
Posted on Apr 18, 2008
  • ABRsvcs Apr 18, 2008
    I'll need to look up your specific model. I'm on the road at the moment, so I don't have the manuals with me. Stay tuned...
    Dan
Slow moving lines up screen
I noticed the same lines on my 32" Sylvania LCD. After playing with some electrical plugs, I found that having my Sony PS3 plugged in interfered with my cable quality. When I unplugged the PS3, the lines and slight humming (only noticeable from behind TV) went away. I tried making sure the cable line and PS3 power cord weren't touching but to no avail. I guess I'll just leave in unplugged while watching TV.
Dec 03, 2009 | Sony Televison & Video
Ok my timewarner cable box works i pull up the guide and selet the channel i want but there is not sound or picture coming from the tv.
unplug the box and let it reset for at leat 4-5 min, if this does not fix your problem call time warner customer suppport, they can reset your box over the cable line if needed. Good luck.
Oct 27, 2009 | BoxWave Corporation Motorola RAZR V3...
Sony RDR-VX535 I tried hooking it up to just a TV, no cable box or anything else. I put the 3-pin cable from the Sony's Output to my TV input (only has yellow and white on TV, no red). However, when I...
Red is Audio Right
White is Audio Left
Yellow is Video
You don't say what TV you have so it's impossible for me to guess what the connection it is that you are using. You will not see a signal on any of the channels you will need to select AV or Mode or Input or something similar on the TV
Jul 26, 2009 | Sony RDR-VX535 Player
I have a 47'' phillips lcd flat screen,will my tuner work without using cable box(timewarner) and still pickup all the channels
If the TV tuner has digital connection with HDMI, or th white red and yellow connectors for RCA cable, it will work with the new TV.
If the tuner has only coax round antenna-like connector, then it will not work with TV tuner.
Many new TV also do not have scart cable connector, but adapters Scart to RCA are available.
May 05, 2009 | Philips Televison & Video
Sony 52 Bravia XBR4-14months old,picture very white, ghosting
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Jun 24, 2017 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Convert my Sony kp61hs10 HD Ready to receive HDTV
no need to convert ,,i have same tv,,hdready just means it has no built in converter. You just need a HD converter box or a cable box or dvr that is also an HD receiver.
Dec 14, 2008 | Sony KP-61HS10 61" Rear Projection...
Blue ghost on left side of screen only when on hi def channels
hello its sound like you need to replace the (IC chip) for your blue (CTR gun) .!!! its going bad.!!!hope this help's you ."good luck"
Jul 19, 2008 | GE 46GW947 46" Rear Projection Television
HELP! MY 42" PLASMA TV IS ONLY GETTING BLACK AND WHITE CHANNELS.
If you are connected to a HD cale box using component cables IE (G, R & B) then check if either the Red or the Blue has come loose or unplugged as this will cause most HD sets to revert to a black and white picture.
May 03, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
