Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
Timing is off. How do I set it? This is a Honda v-Twin engine on my Sears Mower
How to set the timing on a honda gx 670 motor with no timing marks
Hi, if it's a newer style bike, it could be like a newer car. Not possible to change the timing.
Dec 21, 2016 | V-Twin Horizontal OHV Engine with Electric...
How do i set valve/ cam timing on an Honda XRV 750 1999 model
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1999 Honda XRV 750 cam timing Google Search
Thread AT Camshaft details
Honda XL600 650V Transalp XRV750 Africa Twin Service Manual Download... $10
http://www.partsfish.com/page/oem-parts-for-honda
Honda AFRICA TWIN XRV650 Owner Manual
Feb 13, 2014 | 1999 Honda XRV 750 Africa twin
Mts 5500 tractor
I have a Sears MTS 5500 tractor, 24 hp, 48" mower, bought new 2008 but used very little; only 127 hours on it. Soon after starting, tractor emits a heavy white smoke. Tried changing the oil, no help. The engine is B & S Extended Live Series, twin cylinders, total displacement .725 liters. Any ideas of what is causing this?
Jul 21, 2012 | Craftsman Garden
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Honda push mower with a twin blade. I
The more slinder blade goes on second. I just looked at mine and it was second or closest to the ground when on all 4 wheels.
Good Luck
May 02, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
My friend has a 18.5 briggs stratton v- twin that
The engine fuel needs to be primed into the carburator and the choke set.
Sep 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Aug 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna YTH 2448 charging/starting problems.
I have just came through the same scenario. I replaced the regulator, but that wasn't enough, I also had to remove the flywheel which exposed the altinator, the altinator was burned up. I don't know why, or how this happened. I went to the local Briggs and Stratton dealer and bought a new Altinator for $65.00, installed it and viola! charging again.
The whole job took about 3 hours, most of that time was finding the pullers and setting them up to break the flywheel free.
Good luck...
Jun 14, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman mower backfiring
if a camshaft came loose the engine would not run at all. IF engine still runs then i would change the head gaskets. these things **** air and cause backfiring when running. but if engine doesn't run anymore i would look on ebay or craigslist for local mower for parts at least.
Feb 18, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
29 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Charles T Nevin
Charles T Nevin
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
