My LG HDD/DVD Recorder Model: RH177 will not accept and initialize DVD RW discs. it also will not play back pre-recorded commercial DVDs. Can record and play back on HDD but not DVDs.Can you help? Ray Sutton
  • walraymond Apr 18, 2008
    Thanks Ginko,
    I tried the laser lens cleaner, but no luck.
    If it's a faulty lens head it may be that it would be uneconomical to have it repaired and I may have to buy a replacement DVD Recorder. Walraymond
  • 156 Answers
Take time to check the links.. they might help..
http://www.avforums.com/forums/archive/index.php/t-466753.html
http://www.fixya.com/support/t225320-lg_rh177_dvd_recorder
Posted on Apr 18, 2008
    Master:
    Sergeant:
  • 461 Answers
Try to reset you LG recorder as below.
1. Remove any power supply from the recorder. Including take the power supply cable from the main Socket.
2. Leave it off for at less 20 min.
Restart again....
  • 4,234 Answers
This sounds like either the lens is dirty and not allowing the disc to be read or the optics have failed. Open up the unit and clean the lens using a cotton swab and alcohol. If that does not resolve the problem, try playing a music CD. If the CD works, I would suspect that the optics are bad. CDs require significantly less laser power to work.
Dan
  • 19,396 Answers
Check that is not a dirty lens problem, start using a lens cleaner disk
  • Ginko
    Ginko Apr 18, 2008
    If you cannot play commercial disks, but you can record your own DVDs
    and play them, then it is a problem with region settings, set up DVD
    for your country/region, if it is not this proceed on following:
    Try also playing a cd, if it does not even play a music cd (it is supposed to), then it is probably a faulty or dirty dvd lens
    Start using a Laser Lens Cleaner disk and solution, often this fix the problem. If it is not enough the dvd cover must be removed, power disconnected and lens cleaned directly with more solution, isopropyl alcool ans a soft cloth.
    If this still does not work, the dvd lens head may be in need of replacement, at this point consider also recurring to a service center.
    Let me know if you need more help.
    Regards
  • Ginko
    Ginko Apr 18, 2008
    If you do not mind jeopardising your dvd integrity you can unscrew cover and clean with a cloth and alcohol. If you decide to proceed in this way I can post cleaning procedure in a couple of hours
    Check this old post of mine for more details on how to clean lens.
My DVD recorder says that it dos not recognise the dice. and will not let me format it
You are probably trying to use a CD in a DVD-RW machine. Go buy the correct discs for your machine.
Sep 23, 2014 | LG RH177 DVD Recorder/HDD Recorder
My LG DVD RECORDER, MODEL RH7500 won't play DVDs.
Check the model specifications for your device. Some players will only accept DVD-R and not DVD+R or not DVD+RW discs. I know it all seems the same, and it's very frustrating, but many companies restrict the type of discs they will allow. My player does +R but not -R. It should still be able to read DVD discs that you made yourself, but they will be of a different type.
Nov 03, 2009 | Televison & Video
Cannot play all dvds on recorder would like to unlock it
My DVD player is just over 12 months old and it cant read the Discs it brings up a message reading NO DISC can anyone help please.
Warren
May 07, 2009 | LG RH177 DVD Recorder/HDD Recorder
Finalise disc
You need to put the disk back into the recorder, select the finalize function from the onscreen menu, and follow prompts. Do you have an owners manual for the unit?
Apr 22, 2008 | LG RH177 DVD Recorder/HDD Recorder
Recording
Hi there. You need to "finalise" the dvd before you can view it.
Playing region 1 DVDs in LG DR165 receroder
go to dvd set up then scroll dow to lock then push 0 seven times
Jan 23, 2008 | LG RH177 DVD Recorder/HDD Recorder
My DVD disc not recognized after loading, how can i fix it? dvd recorder
most of the LG RH177 have such problem...
...so my solutiong is changing the internal drive with the computer DVD-RW(IDE interface)but it need a lot of modification..
.. finally, i able to fit the computer dvd writer into it ....
Nov 18, 2007 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
