Question about Plantronics Radio Communications
I have a new HW251N headset furnished by employer,constant hum in earpiece, IT dept. says nothing wrong with headset.
  • 5,391 Answers
The fault might well be in the thing you connect it too. Ask them to let you try another headset, if that does the same you know for certain then.
Posted on Jul 06, 2010
Need to hard reset motorola mini bluetooth h9
try removing the pairing to your phone and pair again. If this does not work try pairing your headset to another phone and if it does it on that phone then something is wrong with the earpiece return for repairs if under warranty or if you are willing to pay for the repairs if out of warranty or replace ear piece all together as they are reasonably priced these days. If the ear piece works fine the other phone something has gone wrong with the bluetooth side of your phone return for repairs or replace depending on what you can afford to do. I hope this helps.
Aug 26, 2012 | Motorola Mobility H9 Mini Bluetooth...
My Plantronics Blue tooth earpiece gives a constant "three beep" sound. I can hear the other person on the phone but the constant beeps at the same time. The beeps happen also when the phone is...
The three beeps usually indicate low talk time. If you have tried turning off and on your headset and still have the annoying beeps, then there is a problem with the device. You'll need to contact your retailer or Plantronics (800-544-4660 x5538) for warranty replacement. If it's out of warranty, check out our website Headsets Direct for the latest in Bluetooth headsets.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
Using it on my Mitel 5330 IP phone. Worked for a long time then started cutting out. Replaced batteries in Vista M22 amplifier even bought a new headset still have same problem
It sounds like you have a short in the wiring. Mitel has their own cordless headset for the 5330 model phone... it is awesome in every way. Battery life, range, clarity, etc.
Jan 18, 2011 | Plantronics HW251N Headset
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Oct 14, 2010 | Plantronics CS70 Wireless Headset
Trying to connect my bluetooth to a new cell phone
turn on your cell; go to settings; find bluetooth settings;turn on bluetooth; find audio device choose search; then turn off the earpiece the light will be red next: turn on the earpiece again the light will flash blue and, the cell will find the earpiece the earpiece will flash blue slowly; once a minute
close the cell; use the earpiece
Sep 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
New - but will not charge up (no light on earpiece).
probably the wire from the charger is bad. Try to replace the charger
May 20, 2009 | Plantronics Explorer 340 Wireless Headset
New cell phone won't "see" bluetooth earpiece
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
Feb 14, 2009 | Plantronics Explorer 330 Headset
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
Radio Communications Logo
124 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
