Question about HP LaserJet 2840 All-In-One Printer
I have an HP 2820 All in One and the scanner will not work at all.Printer does work
  • 4,889 Answers
What happens when you actually try to scan? DId you install the scanner driver? IF yest then do you see an error message on the screen when you try to scan?
Posted on Jul 06, 2010
2820 error 2
Kevin_Trenow is correct with his solution to the HP colour Laserjet 2820 error code 5 problem - Thank you.
The symptoms are that the machine turns on but after initial movement of the lighted up scanner, there is a disturbing ratcheting noise as if the scanner is trying to move but can't. The machine comes up with error 5 and suggests turning off and on again - this is a waste of time.
1. The top document feeder is released by detaching the multiplug and simply (carefully) removing the whole section.
2. This allows the removal of 8(?) screws from the second layer which contains the glass platform. The screw heads were removed using a star drive, labelled CR-V T10. (Buy Draper 31 piece Precision Screwdriver and Bit set; part no. PSS31)
3. Carefully lever off the grey surround with button labels on it - probably between 6 and 8 clips attach it.
4. Now lift/gently lever off the glass containing layer.
5. Use a spectacle wipe or erquivalent to wipe the glass over the white strip (This is the problem - the scanner light needs feedback from the white strip to end up in the correct position - the 'ratcheting noise is caused as the stepper motor continually moves the head to find the feedback point)
NB. The glass above the white strip will look perfectly clean - looks can deceive!
6. Replace the glass containing layer, ensuring it is clipped in - don't screw up yet in case more cleaning is required
7. Turn on and the scanner light should end up in the required position.
8. Replace screws, replace lid, push on grey panel and you should have a fully working machine for the price of a spectacle wipe.
Mar 13, 2012 | HP LaserJet 2820 Printer
HP LaserJet 2840 and the scanner not working it stops suddenly and has some noise it says on the screen error5 I turn it off and again on but still not working, thanks
Scanner 5 error is usually caused by a failed scanner head drive motor. HP does not sell that part by itself, you must buy a new flatbed assembly. Can sometimes be caused by dirty mirrors, check my tips on cleaning the scanner on the 3380 as it is the same procedure.
May 18, 2011 | HP LaserJet 2820 Printer
The bulb in my hp 2820 printer does not move even when am scaning
If the scanner head does not move, you need to check two things:
1) If you look into the flatbed while it IS NOT ON (important there), if the bar is off track, it needs to be placed back onto the track.
2) The motor for the scanner apparatus is dead. Buy a new AIO Printer.
Apr 05, 2011 | HP LaserJet 2820 Printer
HP 2820 scanning steps
http://www.google.com.ph/search?q=how+to+use+scanner+in+HP+LaserJet+2820+Printer&ie=utf-8&oe=utf-8&aq=t&rls=com.yahoo:en-US:official&client=firefox
go to this link above, on the bottom you can see HP Color laserJet2820/2830/2840 userguide HP color Laser Jet, left click on this file and you can download the user manual of this printer.
Nov 27, 2010 | HP LaserJet 2820 Printer
Scanner error 5 when turned on
scanner assy. needs to be replaced (the upper part with glass)
order from hp scanner assy. and machine will work as new again.
Sep 23, 2010 | HP LaserJet 2820 Printer
Scanner error 5 or 6 in hp 2840 printer clean glass /lamp but nort working
Replace the Scanner assey, If it's same, Replace the formatter board.
Jan 19, 2010 | HP LaserJet 2820 Printer
Hp 2820 scanner error 5
I'm not sure if this will help or if this is the same as i had but I had been given A laserjet 2820 which keep't coing up scanner error 5 the chap that had it before me contacted hp service & was told to replace scanner unit which he did & it was ok for a while like 6 months & started then started again.
The problem he had was powered up ok till it came to scanner bulb warming up the scanner unit moves back & forth then try's to escape through the right hand side of case.
This is because it cant see the home position white strip under the scanner glass all you have to do is remove top section of the scanner unit complete with scanner glass & clean the under part of the scanner glass the white strip is located under the wide gray panel as you look down on the scanner glass with the lid up. hope this is of some use. my unit has been working for some time now
Dec 29, 2008 | HP LaserJet 2820 Printer
HP Printer Color LaserJet 2840 Printer makes clicking noise and shows on display: Scanner bulb warming up - scanner error 5 Turn off then on but this does not work. Is it mechanical problem or software...
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
Oct 13, 2008 | HP LaserJet 2820 Printer
Clear error code on hp 2820
Could be scanner assembly or formatter
Jun 24, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2820
The flat bed scanner assy is bad and needs to be replaced. The part number is Q3948-60191. Hp recomends taking it to a repair center for replacement
Jan 13, 2008 | Office Equipment & Supplies
HP LaserJet 2840 All-In-One Printer Logo
Seeker5211
Seeker5211
