Question about Proform Exercise & Fitness
Treadmill with really loud noise
My treadmill is making a loud noise when you turn it on, and the noise gets even louder when you start to walk on it. It's so loud that you have to turn the volume on the tv all the way up to hear over the noise of the treadmill.
    Master:
  • 497 Answers
What is the exact model?
Posted on Jul 06, 2010
My treadmill is making loud rumbling noise when I turn it on. It continues while I'm walking on it.
You have to lubricate the waking belt. To know how to lubricate the treadmill belt check the video.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 30, 2016 | Exercise & Fitness
Healthrider H55t makes a clicking noise
Check the front roller. Remove the drive belt and run the motor. If the noise is not there replace front roller.
Jan 01, 2014 | HEALTHRIDER H55t Treadmill with Doorway...
Loud treadmill motor
First get down and listen to where the noise is coming from, is it from where the motor is, or the rollers at each end of the treadmill? There may be dirt or hair stuck in some rotating part, or it may be the motor bearings wearing out.
Dec 15, 2013 | Reebok CrossWalk RT 5.0 Treadmill
Have proform xt 70. It makes a loud noise when turned on, less noise when walking.
see the video and do it inmediately+ roller bearing Too. God bless you
Jan 07, 2013 | Proform XT 70 Treadmill
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
I have a proform 350 treadmill and when i cut it on it makes a loud noise. The faster you go the louder it gets my husband took the front piece off and noticed that the the end piece on the roller is...
The roller is not difficult to replace, it is also no really expensive.
Part number is #219035 it is around $80 from the manufacturer.
The phone number to order the part will be found on the model/serial number tag on your treadmill.
When folded, there is a tag on the frame of the treadmill with a correct model and serial number and the 1-800......
Jan 09, 2011 | Proform 530 Treadmill Walking Belt
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Too noisy problem which is annoying during exercise.
The make and model of the treadmill would help. Your treadmill has 100's of moving parts so the noise can be coming from anywhere. Suggest starting the treadmill with no one on it. Does it still make the noise? If so from where? No noise? Then has someone walk on the treadmill and try and isolate the noise. You may need to remove the motor hood.
Jul 28, 2010 | Proform 540ls Treadmill Walking Belt
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Exercise & Fitness Logo
795 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
