Question about Proform Exercise & Fitness
Loud noise My treadmill is making a loud noise when you turn it on, and the noise gets even louder when you start to walk on it.
My treadmill is making loud rumbling noise when I turn it on. It continues while I'm walking on it.
You have to lubricate the waking belt. To know how to lubricate the treadmill belt check the video.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 30, 2016 | Exercise & Fitness
Healthrider H55t makes a clicking noise
Check the front roller. Remove the drive belt and run the motor. If the noise is not there replace front roller.
Jan 01, 2014 | HEALTHRIDER H55t Treadmill with Doorway...
Loud treadmill motor
First get down and listen to where the noise is coming from, is it from where the motor is, or the rollers at each end of the treadmill? There may be dirt or hair stuck in some rotating part, or it may be the motor bearings wearing out.
Dec 15, 2013 | Reebok CrossWalk RT 5.0 Treadmill
Have proform xt 70. It makes a loud noise when turned on, less noise when walking.
see the video and do it inmediately+ roller bearing Too. God bless you
Jan 07, 2013 | Proform XT 70 Treadmill
2004 town and country whining noise louder when turning the steering wheel
Bad steering rack & or steering pump
Try flushing the fluid, as you should be doing every 3
years on all vehicles
After that-- have to diagnose & start changing parts-- if
you don't like the noise
Nov 23, 2012 | Cars & Trucks
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
It started making a loud noise and when I turn it on and step on it it doesn't even run...what can I do?
Hi, did you fix you treadmill's loud noise?
I have a 530X Proform and I'm having the same problem with my.
May 21, 2010 | Exercise & Fitness
TV is making a loud ear piercing noise.
Ur high voltage is going through FBT,the big black block of plastic with a wire red or gray solder to the board.The Flyback transformer.There a steel "3 inches like a paper clip like steel.Put some supper glue on that "3 steel paper clip look like, will help or stop loud wishling noise all together.
Apr 21, 2010 | RCA HD52W59 HDTV Projection Television
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Exercise & Fitness Logo
203 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
