I have a marshall 100w JCM 2000, DSL 100 Head, going into a 1960 A 4x12 cabinet. Which inputs and settings should i use on the rear of the amp in order not to damage it
Most 1960 cabs have an option for 8 or 16 ohm... i dont think there is a 4 ohm option. The Jcm 2000 heads have the ability to do all three ohm setting. Thats all you really have to worry about. Make sure the ohms match up. The 1960 cabs typically have 4 t-75 speakers in them which are 75 watts each so wattage is not a problem. There is some argument about what ohms sound best. It doesn't really change that much in the sound in my personal opinion. I run mine at 16 ohms though cause i think it sounds brighter...
Posted on Apr 17, 2009
MY Marshall JCM 2000 100Watt head is quiet TURNED fully on stand by OFF and ready to plug guitar into the INPUT Jack. Soon as I plug into the INPUT Jack cracking noise hissing noise.
I would suspect a bad cable. Also, these symptoms show up if you mistakenly use a speaker cable (unsheided) as a guitar cable (shielded).
Dec 12, 2016 | Marshall Music
I have a marshall jcm 900 slx 100 watt head and 1960a cab, when i went to use my amp i got no signal from my guitar. none of the fuses had blown and there was still a hum coming through the speakers. I...
It sounds like you have a dead guitar cable or the preamp section of the amp is blown. It needs to go to the shop. It's way cheaper in the long run to just take an amp in. If you try poking around without knowing what you're doing you can fry something more expensive or worse yet yourself! There are leathal voltages in a guitar amp!
Aug 17, 2017 | Music
How do I correctly connect my mg100hdfx head to a marshall stereo cabinet? Do I connect cables from both outputs from my amp to both inputs in my cabinet?
the second jack is usually for a second cabinet.
http://www.marshallamps.com/downloads/files/MG100%20hbk%20Eng.pdf
here's a link to the manual. to be sure.
if it has effects on it, you may require two cabinets for the stereo effects. in the truest sense of stereo is what i mean.
Feb 27, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall DSL 401 runs fine for about 10 minutes from cold then starts to crackle and sound disappears The amp is fairly new with not a lot of use
if this a tube amp then your tubes might be going bad. but if it is a solid state amp then im not to sure whats going on.
Mar 01, 2010 | Marshall Amplification Marshall MG250DFX...
Marshall DSL 100 - volume fades away and gradually comes back on
IF this is a vacuum tube unit, these symptoms are that of a tube that the heater is intermittent, that is it cools off due to a break and then liights again.
Open the back and observe the heaters in the tubes. DO NOT be fooled by some that have TWO heaters in them. (use a mirror if necessary) A single one that comes and goes can cause the problem and the voiration can make it come and go. This behavior in a tube is NOT somthing readily spotted in a tube checker. The delay in fading and coming back would be the delay in warm up following a heater going out and cooling.
Feb 14, 2010 | Marshall Amplification Marshall MG250DFX...
Marshall JCM 2000 dual super lead 50 watt going out on me
Very nice amp!
First off, is the amp getting sufficient power? An unreliable AC current from your wall can affect the performance.
Have you tried the amp with a different speaker? Checked for a loose connection from the amp to the speaker? Is it the correct ohms rating?
Second, are you experienced in electronics? The problem could lie in a faulty solder connection, a bad component, etc.
If you are not confident in opening the amp and troubleshooting it yourself, take it to a audio repairman. Marshall's are some of the easier ones to fix.....
Nov 22, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Marshall jcm 2000 dsl 100 head not powering cabs 4/8ohm outs
Since you are getting some output, the amp section is probably OK. There are circuits designed to handle thge difference impedence outputs. This should be a relatively simple repair for any shop that handles these units. If you don't have one local to you, let me know and I'll locate the service info and get you more specifics.
Dan
Mar 06, 2009 | Audio Players & Recorders
Marshall jcm dsl 100 head
try to find any diagram from a website.. then print it and give it to your amp tech. so he could Identify what are the wrong, what the first guy did to your amp and its better to buy a whole new tubes. I know your amp tech is very good. I'm just a noob about tubes yet I want to know how this works. hoping for the best for your amp tube.
Jan 25, 2008 | Marshall 82 WTS LITHIUM BATTERY, 3 LED...
106 people viewed this question
 Grubhead
Grubhead
